Question about Hitachi 60SDX88B 60" Rear Projection Television
Hitachi 60SDX88B I have a Hitachi 60SDX88B and the picture just cuts off but you still have sound. It comes back on "sometimes" after a while of being off. Last night I was in the room when it went off and it's was like one of the old TV?s powering off where it goes down to a small dot. It is an older TV and I do not want to spend a lot on it I have experience replacing parts on amplifiers so any help would be appreciated.
  • cindylmb Sep 27, 2008
    i have a problem with the hitachi TV. The picture goes out, but the sound stays on.
  • 513 Answers
First of all: If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. It can be much more tricky then working on an amp, and dangerous, be warned... If you don't want to spend too much money, and since you're describing intermittent failures, I would suggest that you open it up and clean the hell out of it, then resolder the connections to all hot parts, plus any solder points that look cracked. Replacing parts can start as low as 10 $, and up to hundreds, so better try resoldering first. Good luck
Posted on Mar 02, 2006
SOURCE:
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
NO picture or sound.  The red power light goes on and the green lights inside of tv are on. but nothing is working on the screen
You have a problem with the high voltage section that drive the projectors. Look in the back to see if the three projectors are lit. Then we go from there.
Jun 30, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Hitachi 60sdx88b
i will try to help you on that one too as soon as I can get a repair case history on that particular model.
Jan 27, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Hitachi 60SDX88B - serial V9C005014 - Rear projector IC's problem
The most commond problem is Q777. Check that transistor and check Q657 and EP98 also. This should take care of the problem.
Jan 25, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Blank screen,power led on, fans running
Do you have a DLP or Plasma set????? Give me the model #.
Apr 01, 2008 | Hitachi 60SDX88B 60" Rear Projection...
Red deflection is way off, picture scrunched into top right corner
call 800-648-6657 order part number CZ01341. This is the convergence output ic. You will need to replace the red convergence output ic IK04.
Dec 27, 2007 | Hitachi 60SDX88B 60" Rear Projection...
HITACHI 51F59 51 " TV -- NO SOUND NO PICTURE
If it is only a few days over the warranty call immedieatly, if it is much over that then these newer Hitachis are in my opinion not worth repair, and I mean the newer under $1000 units the parts are near the origianl cost sometimes.
Jul 05, 2007 | Hitachi 51F59 51" HDTV Projection...
Hitachi 60SDX88B 60" Rear Projection Television Logo
137 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
