Question about HP DeskJet 3550 InkJet Printer
Test page from hp 3550 with out attach computer
Dear Sir,
Please tell me how i can print test page from hp 3550 printer to check the printer is working or not
  • HP Expert
  • 199 Answers
Power on your printer.
While press & hold power button open & close the top cover for 5 times and release the power button.
Posted on Apr 01, 2010
  • HP Master
  • 19,396 Answers
If you cannot test print page, that it is because the printer is not working.
  • Try uplugging power cord and printer USB cord,
  • Go to Control panel>> Installed printers
  • Remove the printer from control panel, if there is more than one printer that you do not need , remove them all.
  • Restart computer
  • Reinstall drivers, either from printer CD or download from HP website. Keep printer USB unplugged while you reinstall drivers.
  • Plug in printer when asked by driver installation.
If it still does not work test the usb cable, if cable is OK, printer may be faulty, or there is a problem on Windows.
Posted on Sep 09, 2008
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
My deskjet 3550 printed its test sheet and now goes through the motions without printing anything ie ink does not go on paper
make sure that u ink in the cartridges, u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer next use this printer as a default one will give u an option to print a test page on "no" and hit next try to print and check
Nov 12, 2009 | HP DeskJet 3550 InkJet Printer
HP Colour Laserjet 3550 printing problems
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
Mar 11, 2009 | HP Color LaserJet 3500 Printer
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
Printer does not function
In most cases this is caused by a faulty driver or a broken printer cable. Please try to print an internal test page to ensure the printer itself is working properly, then replace the cable and ensure the driver is pointing to the right port if the internal test page prints properly. Also you could try to print the driver's test page (driver properties > Print test page > answer "Yes" anyway, since answering "No" only produces a bunch of suggestions that won't help you solve the problem!). If this works, the problem resides somewhere between the driver and the application(s) you're trying to print from.
Jan 22, 2009 | HP DeskJet 3550 InkJet Printer
Printer is not loading paper
The blinking lights are probably error codes. By the sequence, you can tell where the problem is. Also, you should be able to hold down certain buttons, when you power on the printer, to get tests.
Check the HP Support Website for more info...
Oct 21, 2008 | HP DeskJet 3550 InkJet Printer
Hp deskjet 3550 problem
Green light blinking is indicated that u r one of the cartridge (or both cartridges ) are faulty .please check u r printer with tested Ok cartridges should be resolved
if this information is useful for u please Rate me .........
u r Rating is Important for me.
Jun 26, 2008 | Office Equipment & Supplies
Printer hp D1460
Please provide more details
Does the unti power on correctly ?
Can you see lights and the power up self test ?
What happens when you try a self test ?
Do you hear paper trying to be fed into the machine ?
are there any error messages ?
Feb 09, 2008 | HP DeskJet 3550 InkJet Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
HP DeskJet 3550 InkJet Printer Logo
660 people viewed this question
Ben Johnson
