Question about Refrigerators
Water leaking from Samsung SR394NW refrigerator
  • 1 more comment
  • wallaby1 Sep 09, 2008
    Now fixed. I removed the false panel at the back of the freezer and the defrost drain was iced up. I think it was because I went on holidays for two weeks and the freezer did not get opened at all so it kept on getting colder and colder till it froze over
  • Anonymous Nov 17, 2008
    Water leaking from top vent hole in fridge section
  • miltonmilu Feb 02, 2009
    I bought this Refrigerator (Samsung SR394NW) couple of month ago and having water leaking from top vent hole in fridge section (Bottom part). Please provide solution. from last solution i see the person removed the false panel from back of the freezer. can it be possible to tell more specifically, i have the same model but couldn't locate any false panel. please help.
I have a similar model (SR395NTS) with a similar problem. Have a look at the bottom section at the rear of fridge. You will see a corrugated hose that drains to a plastic tray as part of the defrost mechanism. I found that this was backed up and was able to pull it out to empty it into the tray.
Posted on Mar 29, 2009
  • 75 Answers
The rubber sealing would have worn out so change the rubber sealing
Posted on Sep 09, 2008
Our Samsung Fridge Freezer model RSH1DBRS is leaking water into the bottom of the fridge area - we have tried defrosting but it is still leaking - anything we can do?
Do you have water dispenser in the door? If you do the water holding tank in the refrigerator could have a crack in it and is leaking, I just recently had to replace the tank in my refrigerator
Nov 26, 2016 | Samsung Refrigerators
I have a very small dribble of water leaking from the bottom of the control panel on the freezer door. Is there a simple fix or do I need a technician? Unit is a SRS615DP.
Maybe and maybe not.
Page 9 of the user manual mentions a anti sweat heater that you can turn on or off.
Samsung SRS579NP User Manual Ice cold Water Dispenser
It maybe that the water line to the water dispenser is leaking
I am including a link to youtube videos about refrigerator water leaks but there is little about Samsung. Hopefully turning on the heater will solve your problem. At least one of the videos shows how to replace the tubing in a different brand of refrigerator.
samsung side by side water leak from freezer door YouTube
Sep 29, 2014 | Refrigerators
WATER LEAK SAMSUNG RB215LASH
When water is leaking inside of your refrigerator, the problem could be as simple as condensation from humidity or a worn gasket, especially since you purchased your refrigerator used. The problem could also be a clogged drain or frozen evaporator.
To help you determine the problem, along with solutions that you can use, check out Refrigerator leaking water inside for some simple troubleshooting steps. I hope that helps!
Aug 02, 2012 | Samsung RB215LASH
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
Samsung fridge is leaking water
Probably one of the plastic tubes under the refrigerator is leaking.
Apr 04, 2009 | Refrigerators
Pure water dispensor leaks around the edge.
hi, this is a seal leak. its located behind the water release point. it could also be cracked, the assembly that is, but im sure its just a seal issue.
Feb 12, 2009 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
500 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
