Question about IBM ThinkPad T40 2373 Notebook
Battery indicator flashes even when plugged in to electrical plug, computer recognizes plug-in. Computer will not run with power cord.
  • Anonymous Sep 30, 2008
    my old battery is broke almost 9 month, so i decide to not used since that time. after all, i buy new one. i plug for the first time, n charge till full. but the full led (green) is blinking, wierd. i pull the ac cord, n i try to boot, but only took 5 second and shut off. without any sign. but when the light full(green) blinking, i try to start the laptop, it works normally until i pull the ac cord. what green led blinking means?
  • Anonymous May 19, 2009
    My battery power meter shows even when my computer is plugged in.
    Scholar:
  • 65 Answers
The battery indicator flashing when plugged in to electrical plug means your battery is completely dead and won't charge. You're computer should run with just the power cord. Your power cord most likely needs replacement.
If you know anyone with the same model of laptop ask if you can borrow their power cord and/or battery to test it out. It is rare for the problem to be the motherboard, though it does happen.
It may just be the power cord at fault as the computer should run without the battery, so you should replace the power cord, as it is probably the reason the battery is completely dead.
If the battery is at least a year old I would replace it since they generally don't last too much longer than a year.
Posted on Sep 09, 2008
The battery is fully charged, and the ac adapter is plugged into the laptop, when i push the on button the laptop will not start
Remove the battery and power source. Remove the RAM and hdd. Power up with the power supply and it should do something. If it does, replace the RAM and hdd it should now restart. If nothing, check the GPU.
Jan 10, 2017 | Computers & Internet
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
3gfi plugs on a coachman Aurora do not bathroom bedroom work fine.
sometimes, a GFI will be controlled by another GFI. Did you "reset" the GFI ( if there is one ) in the bathroom? You have to find out where
The wires in the dead GFI come from. Electrical panel....circuit breakers. Did you flip each circuit breaker off then on to reset them ?
Do you have an electrical meter ? let me know then we will go from there.
Oct 13, 2014 | Computers & Internet
How to enable bluetooth
Your computer has to have a bluetooth radio. You can check
Control Panel > System and Security > Device Manager
Do you see a Bluetooth Radio listed?
If not, you don't have BlueTooth on your computer so you will have to add a BlueTooth device by plugging one into a USB port.
If you have a BlueTooth radio, go to Control Panel > Hardware and Sound > Device and Printers > Add a Bluetooth Device
This option is used to connect a blue tooth device (e.g. bluetooth headphons) to your laptop through your bluetooth radio.
See this Windows web page for more information.
Set up Bluetooth enabled device
I will respond to any additional questions you have.
Aug 05, 2014 | Dell Inspiron Computers & Internet
Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
Mar 21, 2014 | Computers & Internet
How to fix computer problems for free
First make certain you have a virus program running and do a full scan. There are free ones around, most use AVG. You can get pop-up blockers, or look at internet options and select block pop ups.
Visit the following website called Black Viper. Follow the instructions and that should speed up your computer.
http://www.blackviper.com/
Mar 07, 2014 | Computers & Internet
Button keeps blinking
It sounds like it could be either the battery is going bad and not holding a charge or the adapter is. I have had really good luck with similar problems going to places like Batteries +, and large electronic retailers, and my favorite the small local mom and pop computer store; where I end up asking them If I could try one of the adapters from the floor model to eliminate if is a faulty adapter. Other then that I'd if its not out of warranty contact Acers online chat support at http://us.acer.com/ac/en/US/content/service
Jan 19, 2014 | Computers & Internet
Www.hp.com/go/techcenter/startup
My computer is appear " The System BIOS has detected that your notebook PC was not into hibernation or shutdown to avoid overheating.The system is now operating normally.
Overheating may occur if the cooling vents are blocked or the operating temperature exceeds the specification.The notebook PC should return to normal operation once the situation is resolved."
System temperature (90D)
Apr 08, 2012 | Computers & Internet
How to install bluetooth on my pc
This depends on what kind of bluetooth you plan on using. Certain things like a Blu-Ray DVD Drive needs to be installed and hooked up internally in your PC, while something like Headphones or a Keyboard simply just needs a USB-based transmitter or a Bluetooth card that plugs into your computer.
Hope that helps,
Aaron Busch
Jan 01, 2011 | Computers & Internet
IBM ThinkPad T40 2373 Notebook Logo
568 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
