Question about LG GC-151SA Compact Refrigerator
REFRIGERATOR LEAKING AT BOTTOM RIGHT CORNER. NO WATER IN PAN
  • Anonymous Jan 24, 2009
    GE PROFILE FRIDGE IS LEAKING AT BOTTOM RIGHT CORNER
  • lkojio May 11, 2010
    How do I access the evaporator plate?
    Thanks for your help.
  • 70 Answers
Sounds like you have a blocked drain, the drain is located under the evaporator plate, you need to clear it and run some hot water though it :)
Posted on Sep 09, 2008
Water is freezing in the bottom drawer GEProfile bottom drawer freezer and leaking water on floor
Sounds like your drain tube is blocked in the freezer for the defrost water. The drain tube is in the back left or right corner and will have a drain trough under the cooling coils tilting towards it. That trough will probably have ice built up all over it. Once the ice is out you may need to force hot water down the drain tube. I use to use a turkey baster with a rubber hose on it to force the hot water down the drain tube. Its clear when you put water in the trough top and it goes down the tube freely to the drain pan under the refrigerator.
Feb 28, 2015 | GE Profile PDS22MHR Bottom Freezer...
Water is leaking on floor from left hand front corner (freezer side) I noticed it does it on the right hand corner at times also
On my fridge like this one, on the freezer side, down at the bottom (below the doors, where the vents are, there's a turn knob there. If you turn it counter clockwise, it'll unscrew filter. It's white and about 2" round and 10" long. It's the filter that goes to the water supply and ice maker. Mine had stopped up, I just pulled it out, went to home depot and got another just like it and re-plugged it in.. No more leaks for me!
Dec 07, 2012 | Frigidaire FRS26R4A Side by Side...
Have a kenmore bottom freezer and when it is humid water leaks from, I gues the drain pan, and stops leaking when humidity drops. Any suggestions other than me putting a towel at the bottom right of the...
you may have a crack in the drain pan. or you drain line has a hole in it . remove your drain pan check for cracks. some glue can repair that, an glue can repair your drain line too.
Jun 03, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
LEAKING FROM BOTTOM RIGHT CORNER
Either leaking water valve, or possible cracked drain pan.
Apr 28, 2010 | LG LFX25960ST Stainless Steel French Door...
Water leaking from the bottom
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 16, 2009 | Refrigerators
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Leaking refrigerator
that is where the drain pan is located. it seems that the drain pan is overflowing which should not happen.
kindly check the condenser fan located at the back near the compressor. it should be the one blowing warm air at the drain pan to heat the water to evaporate.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Hotpoint HSS25GFP Side by Side...
Water leaking from fridge
Hello I had a problem close to this, at the back of the fridge on the bottom you should find the motor ,sitting on top of the motor there should be a small cream plastic catch tray if you dont have one this may be the problem as the motor evaporates the excess water, Hope this helped. djdizzys
Feb 14, 2008 | Refrigerators
Fridge Leaking water from front right hand corner
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
Oct 19, 2006 | AEG SK78800I Compact Refrigerator
LG GC-151SA Compact Refrigerator Logo
291 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
