Computer crashed, won't go to windows - Computers & Internet
  • Coss May 11, 2010
    What kind of errors does it report?
    Problem Solver:
  • 9 Answers
When you start you computer, after the bios flash. press the F8 on your keyboard before the Windows start loading. You should have an option to select to go to safe mode.
Select the safe mode option only. See if it will load the Windows under the safe mode option. If it did load the Windows under safe mode. There is an issue loading the driver of your Windows O.S. that i why its not booting under the Normal mode. Sometimes this is cause also by a Virus on your computer. You can run the Anti-Virus program under Safe mode to check for viruses
To fix this you may need the Original Disc of Windows O.S.
You can reboot the computer. Load the disc make sure that under the Bios option the CD drive is the first boot. Then save it.
after rebooting. Follow the on screen instruction on how to repair the O.S. There should be an option to repair the O.S. when you boot the computer using the Windows O.S. Disc
Note:
If you could do a backup of your files, do it first before repairing the O.S.
If it will not resolve the issue, you will have to reformat your computer.
Posted on Sep 09, 2008
When I turn on HP pavilion windows 8 os it says starting automatic repair and then goes to black screen
this is a commom issue with windows 8 on HPs. turn off your automatic updates then contact windows. the updates usually gets to 13% and then freezes.
Jul 27, 2013 | HP Pavilion Computers & Internet
Won't boot linux cd
Try changing the boot order to HDD.
Mar 07, 2013 | Gateway Computers & Internet
Computer won't startup gets stuck in driver loop
if you have a PC then when it has the codes there will be options so you click on "start windows normally" because it is in safe mode that happens after your computer has dump crashed. so if you change it that might help! good luck
Oct 05, 2012 | Sony VAIO VGC-RA820G (027242657700) PC...
G71-448cl won't boot
It is possible that your hard drive has crashed in the computer.
classic symptoms. However; a technician will have to diagnose
if you are having a power problem. It isn't turning on. Verify that the cables are functioning properly.
Sep 17, 2012 | Computers & Internet
Windows XP won't load on my emachine t3516
You may need to check to make sure Windows XP was installed properly, if the computer had crashed, you can do a repair, I am a computer technician, and I can tell you, that replacing the power supply will not do that.
May 20, 2012 | E-Machines eMachines Desktop PC
My computer drive crashed. How can I retrieve the data?
If the operating system program was all that crashed, then yes, you may be able to recover data. If the hard drive itself failed totally, then your only possible option is to take it to a data recovery specialist. They can often recover data off these devices as they have special tools and software to do it. They are expensive, though, so unless the data you are looking to recover is very important to you, it;s probably not worth the cost.Now if the hard rive itself still runs, but just won't run Windows, you can remove the hard drive and connect to to another PC as an add-on drive and access the files that way.
Jan 14, 2012 | Computers & Internet
My computer problem is 0x3bc3 just crashed
Saw a solution in the web and it helps. Try the following step;
"System process at address 0xE4783995 have just crashed, please follow these steps to deactivate it from your system." is a fake warning and the only visible part of the infection which is defined as a Trojan/Ransomware. It's a piece of malware that blocks pretty much everything on your computer and demands payment in exchange for the identification key. In order to remove the "System process at address 0xE4783995 have just crashed"
STEP
Enter this code: 754-896-324-589-742 to unlock your computer.
HOW TO UNINSTALL IT
To remove all System process at address 0xE4783995 have just crashed files, you must kill all System process at address 0xE4783995 have just crashed processes that are running in your computer's memory. To kill System process at address 0xE4783995 have just crashed processes, press CTRL+ALT+DELETE to open the Windows Task Manager. Click on the "Processes" tab, search for System process at address 0xE4783995 have just crashed, then right-click it and select "End Process" key.
You'll also need to remove System process at address 0xE4783995 have just crashed registry keys. To remove System process at address 0xE4783995 have just crashed registry keys, click on the Windows "Start" button and select "Run" to open Windows Registry Editor. A window will popup. Type "regedit" into the box, and click "OK". Search for the registry key "HKEY_LOCAL_MACHINE\Software\System process at address 0xE4783995 have just crashed." Right-click it and select "Delete."
Finally, you'll need to manually delete other files to clean your PC of System process at address 0xE4783995 have just crashed. These System process at address 0xE4783995 have just crashed can be in the form of EXE, DLL, LSP, TOOLBAR, BROWSER HIJACK, and/or BROWSER PLUGIN. For example, System process at address 0xE4783995 have just crashed might create a file like
%PROGRAM_FILES%\System process at address 0xE4783995 have just crashed\System process at address 0xE4783995 have just crashed.exe. Locate and remove these files.
Jul 04, 2011 | Computers & Internet
Hi i have labtop acer emachine e 510 when i wanna log in this message appear system process at address 0x3bc3 have just crashed please follow these steps to deactivate it from your system * i cant...
IT is a fake warning and the only visible part of the infection which is defined as a Trojan/Ransomware. It's a piece of malware that blocks pretty much everything on your computer and demands payment in exchange for the identification key. In order to remove the "System process at address 0x3bc3 have just crashed"
STEP
HOW TO UNINSTALL IT
3bc3 have just crashed files, you must kill all System process at address 0xE4783995 have just crashed processes that are running in your computer's memory. To kill System process at address 0x3bc3 have just crashed processes, press CTRL+ALT+DELETE to open the Windows Task Manager. Click on the "Processes" tab, search for System process at address 0xE4783995 have just crashed, then right-click it and select "End Process" key.
3bc3 have just crashed registry keys. To remove System process at address 0x3bc3 have just crashed registry keys, click on the Windows "Start" button and select "Run" to open Windows Registry Editor. A window will popup. Type "regedit" into the box, and click "OK". Search for the registry key "HKEY_LOCAL_MACHINE\Software\System process at address 0x3bc3 have just crashed." Right-click it and select "Delete."
3bc3 have just crashed. These System process at address 0x3bc3 have just crashed can be in the form of EXE, DLL, LSP, TOOLBAR, BROWSER HIJACK, and/or BROWSER PLUGIN. For example, System process at address 0x3bc3 have just crashed might create a file like
3bc3 have just crashed\System process at address 0x3bc3have just crashed.exe. Locate and remove these files.
Jun 29, 2011 | Computers & Internet
My computer is stuck on a blue screen that tell me that config_list_failed.. and i try to boot on advanced options and none of them work.. how can i restore my computer if i cant get on the screen that...
Hi, maybe you can take a try of this rescue program called PowerSuite Golden. I came across similar blue screen situaiton on my HP laptop (win 7) and it helped me get rid of it and rescued my data back. It is an awesome toolkit that includes a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all. Hope it helps in your situation too. Regards
Jun 21, 2011 | Dell Inspiron Mini 10 Notebook
Hi guys, my moms laptop won't load windows, it keeps giving her an error message saying that "windows could not complete the installation, to install windows on this computer, restart the...
Looks most likely that your Moms' hard disk has some bad sector on the boot drive. The best you can do is to reinstall the laptop. You may have to hand over the laptop to someone who is good with computer and has the OS disk to this this for you.
Jun 15, 2011 | Acer eMachines 520-2890 Notebook
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
