Question about DeLonghi Cafe Sorrento Espresso Machine
LCDs flashing and counting up, no other ops avail.
Our sorrento machine just this morning started flashing the LEDs that normally give you the time for your shot and they are counting up to 100 then starting again from zero. The machine is also not letting us pull shots. Have tried turning it off but this did not work.
    Champion:
  • 277 Answers
Hi first: unplug it for a day or a week clean all components well: filters, pipes look for a reset button(i think there is 1?) most of these machines have a short period lifetime good luck
Posted on Feb 26, 2006
Stops during cycle
some times the number of flashes and pauses will be an error code counting them could result in a solution also try turning off the breaker count to 5 turn on see if helps
Nov 25, 2013 | GE DSXH47EGWW Electric Dryer
Spins during cycle, but doesn't fully drain and no final spin
bizzy, as long as you are satisfied that the pump is ok, try putting it into a diag mode and see if we can come up with an error code.  First wake up the machine by pressing any button, then within 5 seconds press and hold the two greyed out buttons on the right  (pause and start cancel). As long as you hold those 2 buttons in, the error code should be flashing. Keep holding them in. Now you will have to count the times the 5 leds on the right flash. When they stop, count the times the start button flashes.  This will give you the code.  Post back here with the results and we'll see if we can come up with a code..Catriver
Oct 20, 2007 | Kenmore 44042 Front Load Washer
Clean unable 50
  • Not knowing which printer you have ,here are 2 solutions:
The printer must be reseted:
  • Press menu then*2864 within 2 seconds and press 80.
  • Keep pressing black/mono start button until screen displays 'purge count'.
  • Press 2783 to reset purge count.
  • Press stop/exit key
  • Press 99
  • The printer should return to normal
  • OR
  • Machine off
  • Switch on the machine while holding down the "menu"button until all the leds are flashing on/off. Now you are in "maintenance" mode.
  • Press 80
  • Press the "mono start" button several times until you see "purge: xxxx"
  • Press "2783" in order to reset the purge counter. You will see: "purge:0000"
  • Press the "stop" button.
  • Press "99" to exit the maintenance mode.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 15, 2011 | Office Equipment & Supplies
My MFC-3240C Brother Printer reads: Unable to Clean. What can I do
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
May 10, 2010 | Brother MFC-3240C All-In-One InkJet...
ERROR MESSAGE SAYS UNABLE TO CLEAN
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
Apr 30, 2010 | Brother DCP 115C All-In-One InkJet Printer
Clean uneable 46 brother dcp 130c printer
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
All the best Pineworks
Apr 28, 2010 | Brother DCP 130C All-In-One InkJet Printer
My mfc-210c says unable to clean how do we fix this?
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
Apr 28, 2010 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
Mar 30, 2010 | Brother MFC-5840CN All-In-One InkJet...
Getting error message CLEAN UNABLE 46
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
Mar 07, 2010 | Brother DCP-135C Flatbed Digital MFC...
Hi I have a Brother DCP 130 MFC I have an error message clean unable 4f see troubleshooting maintance chapter in user guide
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
All the Best Pineworks
Mar 02, 2010 | Brother MFC 420CN All-In-One InkJet...
DeLonghi Cafe Sorrento Espresso Machine Logo
93 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
