Question about Panasonic PT-47WX49 47" Rear Projection Television
Continued convergance issue.
I need to explain the problem. The screen went to an hourglass-type view while my wife was watching the tv. It remained this way for a couple of days then my wife smelled something hot/burnt and the tv went out. I ordered new IC units and replaced them, once again the smell returned. I then purchased some panasonic resistors and changed one of the 2.2 ohm resistors and plugged the tv in. The tv came on for a few seconds, not connected to an antenna, and I noticed the very 2.2 ohm resistor turn red and the smell returned. I have purchased another set of IC units, this time they are the 110's instead of the 180's that I upgraded to. My question is if I replace all of the resistors around the IC units (i.e. 2.2, 82, and 120 ohm resistors) what is the probability that this will rectify the problem. I have no manual as one response inquired about.
    Problem Solver:
  • 6 Answers
I have heard from a few people that the higher value IC (150, 180, etc) do handle more current, but also that they *draw* more current, as well. Taking a guess, it may be simply that the 180s you installed were pulling too much juice from the resistors, which is why they popped. These ICs were used in many TVs, so it may be that the Panasonic doesn't have as much tolerance for the 180s' power requirements as, say a Hitachi.
Luckily, resistors are pretty cheap, so it's probably worth the few bucks to replace the resistors when you drop in the 110s you have in hand.
Posted on Sep 11, 2008
While watching my 32" less than 2 year old seiki tv the picture went completely black while the volume still continued. what is wrong?
No backlight. Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
May 23, 2014 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
I believe someone else had this same issue, but I was not sure of the exact solution. After powering up the TV, it took 9 minutes for all of the colors to go out of convergence, and the picture to look...
Sounds like the STK730-130 IC needs replacement. You only need one for your model. Its available from www.tvrepairworld.com its listed under the Integrated Circuits category.
Aug 28, 2011 | RCA P60920BL 60" Rear Projection...
The other day my wife was watching tv and suddenly
Ur convergence is dying or well be dead.3D pics or shutdown.U must know how to solders? The parts in convergence board must change like ICS,and all it resistors.The websites Tv Repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost u $300 for parts and labors.
Jan 14, 2010 | Proscan PS61670 61" Rear Projection...
Sony KP-53V75 picture problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem as shown below. Doing so will only make things worse.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 12, 2009 | Sony KP-53V75 53" Rear Projection...
Sony 53 inch projection screen with hourglass picture
If you are familiar with TV repair, have electronics basic knowledge, good soldering skills and tools then check dry (cold) soldering joints at D board of this TV. Resold all lose connections there and check picture.
Still no joy then you need to replace D board.
Feb 25, 2009 | Philips 60PP9202 60" Rear Projection...
Hourglass Shape
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
Feb 17, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem wiht jvc av 48wp30
Bad chips...There are a ton of cheap fakes out there....Or bad resistor...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 29, 2008 | JVC AV-48WP30 48" Rear Projection...
Detailed problem per your response
The problem is that the ICs may have been blown because the resistors were bad. Just as a double check before you replace anything else. Please confirm that the STKs are STK392-110. Also, replaceing them with STK392-150 is a valid upgrade, I'm not sure about the 180s, but I'll check. Both the STKs and the resistors need to be changed at the same time.
The hour glass view you reported: Was the bowing on the top and bottom or on the sides?
Thanks,
Dan
Sep 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
