Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony kv-36hs510 quick question any help would be much apprieciated. My Sony KV-36HS510, blinks 7 times and will not come back on. Any advice? Sincerely David If you could send response to harleyfordd@yahoo.com
  • harleyfordd Sep 09, 2008
    i have a sony kv-36hs510 tv it continues to blink 7 times the tv will not turn on meaning no picture. I was told i needed a d board. What is the usual cost to have this problem fixed by the tv repair man? Or how much does the d board alone cost? Is it a simple just pull the board out and clip the new board in?
    Thank you for the quick response. david
  • Sony Master
  • 19,396 Answers
    Brigadier General:
  • 6,966 Answers
The blinking leds indicates that the built-in protection circuitry has detected a fault and in order to prevent further damages stops the unit from energizing/powering on. Often 7 blinks indicate probable area where to start diagnosis/checks. In your case, this would be:
  • "High Voltage Shutdown. The high voltage has exceeded 33K and the unit goes immediately into safety shitdown. Check power supply regulation and horizontal circuits."
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional or claim warranty repairs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 09, 2008
    Genius:
  • 2,035 Answers
Blinking light* 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board), you need to replace or get it serviced by the company if under warranty or get it done tv repair personal ,if like to perform DIY then I would recommend going to the following link and getting the service manual so you can see first hand dis assembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a newD board. heres the link.
http://servicemanuals.vstore.ca/
Good luck..
Sony trinitron standby light blinks 7 times. no picture. light continues to flash. tried hard reset. no picture. model sony wega kv-36hs510.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
To get more details, http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Televison & Video
We did not find results for: Sony Trinitron KV-36HS510 worked until we carried up 2 flights of stairs and now it does not turn on and blinks either 6 or 7 times. Is something losemed.
  1. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 900 posts to different brand TVs now.
Oct 02, 2012 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony wega KV-36FS13 standby light blinking 5 times. no pic.
non of the blinks are good but here is yours
\5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
also not a DIY
Please rate my help++++Thankis for using FIXYA
May 19, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony wega KV-36HS510 blink code 6 times
all of the wega TV's blinks before turning on the screen, during that time the system monitors for any system errors,even the quality of the picture is affected the screen wont open.Is the screen open after blinking?
Aug 30, 2009 | Sony Televison & Video
TV wont turn on. Standby light blinking 7 times in sequence.
It will most likely need the power on switch replaced its very common
Jun 21, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
