Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
My refridgerator isn't cooling
My fridge side isn't getting cool enough, but my freezer side is working no problem. I have vaccuumed the coils, made sure the air vents are not blocked, and turned the power off and back on. Is there anything else I can do before calling for service?
    Problem Solver:
  • 18 Answers
It is porobably not defrosting, if there is a coating of frost on the back wall of the freezer side, the unit is not defrosting. this could be due to a faulty timer, or burned out heater element.
These both involve high voltage electric, and should be left up to a pro.
Posted on Sep 09, 2008
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I have a side by side ref/frez Amana ars266zbw the freezer works fine but the refridgerator isn't coolig
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Amana ARS266ZBS Side by Side Refrigerator
I have a Sub zero refridgerator 590, the refridgerator side is not getting cold, and it's icing up inside where the fresh foods are stored, yet the freezer is working fine. Please help
The freezer coils are iced up and that is blocking the sir flow to the fridge.... You have a defrost problem and that is causing the refrigerator to be warm...
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Freezer isn't working and refrigerator isn/t cooling. What is the problem? We can hear the fan running however.
my refridgerator is a Maytag side by side did the same thing checked the freezer compartment fan was working removed cover to look at the cooling coil, the coils were frozen solid ended up defrosting freezer compartment every other day. replaced the adaptive control board located in the refrigerator side top, haven't had another problem since.
Nov 15, 2009 | Maytag MSD2756GES Side by Side...
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerator not cooling but freezes
You might try vaccuuming under the frig to clean the coils so it could disapate the heat more. This could cause that sytem. Also if the fan is not working.
Hoped this helped. If not let us know.
Mar 16, 2009 | Maytag MZD2766GES Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
59 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
