Question about Dimplex Symphony Celeste TDS8515T Heater
Dimplex TDS8515T Symphony Celeste Electric Stove with Purifire Air Treatment
Hi I moved house and cannot locate my user manual for my Dimplex TDS8515T Symphony Celeste Electric Stove with Purifire Air Treatment. I cannot figure out how to turn it on. I put a new battery in the remote control. Thanks Carole
buzzwood
  • 65 Answers
SOURCE: Dimplex SHB20 Sherbourne Electric Stove -Flame Effect not working
Call Dimplex : 1-800-668-6663 ext: 358 they are kind and very helpful, they will send you arts to repair.
Posted on Jan 21, 2009
  • 4736 Answers
SOURCE: Just purchased a dimplex DS5629
Ar e you sure that the receptacle your have it plugged into is working? If it is, you can try this. It usually works. Turn the Master On/Off Switch to OFF. Unplug the unit and leave unplugged to 12 - 15 minutes. Plug the unit back in and turn the Master On/Off Switch to ON. Then, turn each individual function one at a time. If they ail function as they should, the unit has reset itself.
If it doesn't work, then you'll have to wait until Monday to contact Dimplex OR you could contact the retailer you purchased it from and have them replace it immediately. That is, unless you purchased it online. Then, it would be better to wait until Monday and contact Dimplex. Be sure you have your Model Number and Proof of Purchase, when you contact them. In case you don't have it, their Technical Support number is 888-346-7539.
Hope this helps you solve the problem.
Posted on Apr 01, 2011
  • 4736 Answers
SOURCE: light and flame effect not
The light bulbs that provide the flame effect, may have burned out. You can access the bulbs by remove a rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
I hope this helps you and thanks for choosing FixYa.
Posted on Jul 25, 2011
  • 4736 Answers
SOURCE: How do I replace the light bulb in a Dimplex
You can access the bulbs by removing the rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
motor1258
  • 6674 Answers
SOURCE: How to operate the Dimplex CS1205 Compact Electric
Here's a link to downloads owners manual.
http://www.dimplex.com/cms/publications/CS1205_-_7207040100R06_EN.pdf
Posted on Sep 18, 2011
How to operate the Dimplex CS1205 Compact Electric Stove. How to activate the heat and is there a temperature control switch?
Sep 18, 2011 | Dimplex Compact Electric Flame Stove...
Have a melted plug on my heating stove . what causes that and what can I do
Be glad you caught that in time. The overheat or overload sensor for your electric stove-heater has failed and needs to be replaced. If it is still under warranty, Dimplex will repair or replace it at no cost. Even if it's not still under warranty, Dimplex Technical Service wants to know about this. If you live in the USA or Canada, you may call them at 888-346-7539. If you live in the UK call 0845 600 5111 and ask for Technical Service. Either Dimplex USA or Dimplex UK, can provide the part if necessary.
Do Not use your stove-heater until this is repaired.
Hope this helped you. Please let me know.
May 25, 2011 | Dimplex Compact Electric Flame Stove...
I can't to find the area to replace the bulb. Everything works except for the light To eacy to leave on without the light. Where is the bulb located and what should I purchase to replace it. model #...
On the back of the heater stove, you will see a rectangular panel in the center, near the bottom of the stove. If you remove that (by removing the screws that hold it in place), you will have access to the small base, 60 watt. chandelier bulbs that you will need to replace. Be sure to turn the stove OFF and unplug it, before attempting to replace the bulbs.
Hope this helped you and Happy Easter!
Apr 24, 2011 | Dimplex Compact Electric Flame Stove...
Need manual for a simplex symphony sf3003
You can find, download & print the Owners Manual at the Dimplex USA website.
Feb 06, 2011 | Dimplex DF3003 Electric MidSize Heater
My Dimplex DFB 4047 won't get very hot
This is an on going problem with electric fireplace/stove type heaters of all types. Not just Dimplex.
They are not designed to run for long periods of time and the heat output is not much more than a blower dryer. In any event, they take in cool air, heat it and send it back out. Over time, the heating element becomes clogged with dust, lint and/or pet air. So, they have to work harder to produce a sufficient amount of heat. Cleaning the heating element with a vacuum that has a hose and brush attachment may help. The heating element and blower are under the stove. See your Owners Manual on how to access it. Be sure to unplug the stove before trying to service/clean it.
Feb 05, 2011 | Dimplex Compact Electric Flame Stove...
Dimplex manual
HI
you could try here at or even email/contact them these should be able to give you the manual
Dimplex Heating & Fireplaces
riz.
Feb 05, 2009 | Dimplex Compact Electric Flame Stove...
My air heater won't turn on it's a Dimplex DFB6016. What can I do?
call Dimplex : 1-800-668-6663 Ext: 358 These folks can solve your problem and send you replacement parts.
Dec 13, 2008 | Dimplex Compact Electric Flame Stove...
Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
Apr 02, 2008 | Dimplex Compact Electric Flame Stove...
Dimplex Symphony Celeste TDS8515T Heater Logo
50 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
