Question about Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool range I accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
  • 750 Answers
Hello dolphin 1 mom
Welcome tofixya.
You said, accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
Send me your e-mail address and I'll e-mail the diagram with the door instructions for removal and replacement.
It will not fit in here with the diagrams.
Waiting for you.
Huuum
Please do not forget to enter a rating when we are done
These are the installation instructions, but with no diagrams
To Remove:
1. Open the oven door. Insert door removal pins, included with
your range, into both hinge hangers. Do not remove the pins
while the door is removed from the range.
2. Slowly close the door until it rests against the door removal
pins.
3. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on the inside surface.
4. Pull door straight up, then toward you. Hinge hangers will
slide out of front frame hinge slot. Do not remove door
removal pins until the door is replaced on the range.
To Replace:
1. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on its inside surface.
2. Hold oven door so that the top edge of each hinge hanger is
horizontal. Insert hinge hangers into the front frame hinge
slots.
3. Tilt top of door toward range. Slide hinge hangers down onto
front frame support pins. Make sure the hinge hangers are
fully seated and engaged on the support pins.
4. Insert the door stop clip with its angular surface at the top of
the frame hinge slot, then push in the bottom of the clip until
its flanges are flush with the front frame.
5. Open the door completely and remove the door removal pins.
Save door removal pins for future use.
6. Close the door.
StorageDrawer
The storage drawer can be removed. Before removing, make sure
drawer is cool and empty.
To Remove:
1. Pull the storage drawer straight back past the drawer stop
notch and the end of the side rails.
2. Lift up the back of the drawer and pull the drawer out.
To Replace:
1. Lift up the back of the drawer and place it inside the range in
its fully forward position.
2. Lift up the front of the drawer to a level position.
3. Slowly push the drawer into the range until the drawer side
rails engage with the gap in the drawer glides.
4. Once the drawer is fully engaged on both sides, slide the
drawer back into the closed position.
NOTE: When removing and replacing the storage drawer, a slight
push may be needed to move the drawer stop notch past the
drawer glides.
A. Removal pins
B. Hinge hanger
A. Hinge hanger
B. Door frame hinge
C. Support pins
A
B
A
B
C
A. Drawer stop notch
B. End of side rail
A. Engage drawer glide
A B
A
Posted on Oct 03, 2008
WFG371LVS
The oven electronic ignition is bad, very common, to replace remove oven door and the grate shelf, then unscrew bottom panel inside oven , you will see the ignition device towards the back unscrew it and unplug the the electrical plug to remove and replace it. I found them cheaper on line, like Sears parts center, it takes about 15 minutes to change out.
Mar 26, 2013 | Whirlpool GS563LXSS - stainless Steel Gas...
Whirlpool oven door
Hi ShellBrokeIt,
Pivot the hinges outward, and GRop the door by both edges,  Feed the slots of the door onto the hinges and slide it on, Close the door and your done.
Oct 16, 2007 | Whirlpool GR478LXP Electric Kitchen Range
How the side trim for a whirlpool range modelRF378LXK goes
Remove the three screws from the left or right side panel you are removing
Pull the back of the side panel out from the range approximately 45 degrees
Open the warming drawer several inches. Push forward and unhook the three front tabs from the chassis slots and remove the side panel.
See the photo...
Mar 10, 2013 | Whirlpool GR563LXS Kitchen Range
I need to put back the trim on a whirpool range model RF378LXK
Open the warming drawer several inches. Push forward and unhook the three fronttabs from the chassis slots and remove the side panel.
See the photo...
I have a whirlpool electric range model no. RF378LXKQ0. I removed the door and now I can't get it back on. I didn't relalize I was to put the pins in and I don't even see where they go.
**** the hinge to the broil position. Put a nail or something so the hinge won't pop back in the door when you go to put it back. Once ya have it back in the stove, remove the nail and close the door.
Sep 07, 2011 | Whirlpool RF378 Electric Kitchen Range
I need to re-install the door on my whirlpool range
Try and stick the ends of the hinges in the slots on the range lift up a few inches and shove the bottom of the door in with your knees.
Nov 23, 2010 | Whirlpool Kitchen Ranges
Installation oven door
In order to reinstall the door you will need to extend the hinges out on both sides...You will notice a small hole at each hinge..Insert a nail in to each hole (one on each hinge)...Set the hinge so that the it is extended outward with nail in place...Once completed set the door back onto the oven with hinges inserted into slots in housing....Open the door as far as it will go...Remove the nails ..The door should now work properly..
Apr 20, 2010 | Whirlpool GS460 Gas Kitchen Range
BAKING ELEMEN REMOVEAL HOW?
Unplug your range or turn off the circuit breaker for the range,
Remove the oven racks. Use a phillips screwdriver or a 1/4 inch hex wrench to unscrew the retaining screws at the back of the oven cavity holding the element in place.
Carefully pull the element out of the slots to unhook the wires. Make certain the wires do not go back into the holes. Attach the wires to the new element and insert the terminal ends into the holes and replace the screws. Turn the power back on.
If the wires accidentally go back into the holes you will have to pull the range out and remove the rear panel to retrieve the wires.
Dec 31, 2009 | KitchenAid KESC307 Electric Kitchen Range
Can't put oven door back on
Hinge has a small hole in it. Lay door flat on rug. Take a pair of channel locks and tension hinge past hole. Put a screw in hole to hold it open. Then put door on product. Remove screws. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Whirlpool GS460 Gas Kitchen Range
Oven door came off
Got it fixed! I found the owners manual posted on another site with replacement instructions. Expand the hinges from the door and insert a nail or screw into the hole there to hold hinges open. With hanging slots parralel to pins in oven frame slide back into place.Once in place open door completely and remove screw or nail. Couldn't be easier.
Jul 01, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool GR465LXLS Electric Kitchen Range Logo
540 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
