Question about Whirlpool Dryers
I have a ten year old Whirlpool gas dryer. the dryer still tumbles, but it does not heat. What part of parts do you recommend replacing?
The ignitor
Posted on Sep 09, 2008
6 year old dryer will not heat. Gas line & supply
Use this video to replace your gas ignitor.
http://www.youtube.com/user/RepairClinic#p/search/10/NVvI2kbOA-g
Aug 19, 2011 | Whirlpool WGD5320SQ Gas Dryer
My whirlpool dryer, model LGC6646AWO will not heat. It doesn't sound like the electonic ignition lights up. what part most likely needs to be replaced? this dryer is 16 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Whirlpool Dryers
WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 24, 2010 | Abbaka White Knight 38AW Electric Dryer
My Whirlpool dryer has stopped heating-still seems like air flow and tumble is good. Recently replaced computer. Dryer is only 5yrs old.
if your heating element is good then you need to check the thermal fuses in the cabinet if one of those is bad then it needs to be replaced.all thermal fuse should have continuity as well as the element if one of them does not have any continuity then replace it
Mar 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
High pitched squeal when running. Capacity Plus Gas Dryer ten years old.
tumble dryer / twin tub is making a loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing
Mar 09, 2010 | Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Does not dry completely
how well did you clean that duct, the duct is problem 90% of the time when the dryer does everything else, pretty much if the dryer heats and tumbles its doing its job
May 04, 2009 | Dryers
Gas dryer problem
I am getting water in my vent hose. What could cause this.
Dec 13, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
