Question about Kenmore Oasis HE 27062 Top Load Washer
Washer making a weird noise
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I purchased my Kenmore Elite Oasis washer in Aug of 2006. I've already had to replace the main board in my dryer. And now I'm having problems with the washer and of course it's not under warranty any more. Anyway, when the washer starts the rinse or spin cycle it makes a really strange rattling noise. At first I thought that maybe there was something in the washer tub that was rattling around, but there's nothing in there. The noise is coming from the back of the washer and the display isn't flashing any error codes. The washer just keeps running, but something is wrong or it wouldn't be making that noise. I don't want to keep using the washer and ruin it. I have a family of 6 and I need my washer to work. Please help.
We have the HE 27062601 and today it started making loud rattling noises just as described above. I pulled the washer out of position and removed the back. While holding my hand on the drain pump we test ran the washer and could feel the rattling in that pump located in the lower right side of the washer (looking from operator's position). Unplug the washer from electrical outlet. Compress and move the drain hose clamp out of the way and put a catch dish under the pump. Partially removing the hose will allow you to meter out the water. After draining a couple of dishes of water (dog dishes work great), I did the same with the short elbow hose leading to the pump until the pump was drained. With a flashlight, I could then see the dime that was rattling under the plastic pump impeller. Caution... there were actually two dimes so it pays (literally) to double check for all debris in the pump.
    Guru:
  • 462 Answers
I didn't get to answer this but It makes "cents" to me.
Posted on Apr 01, 2009
Kenmore elite oasis washer makes noise and unbalanced
If your washer start going to high speed and it make unbalance and bangin on the frame. there was a stator may need replace....good luck
Nov 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
forgot to include the most important step! We got the dimes out after wadding up a small piece of duct tape, sticky side out, and using locking forceps to grip the tape while fishing out the dimes from the drain pump.
Sep 03, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis washer will not turn on
I have the same problem. I used the unit 2 days ago and no problems- just bragged about the unit yesterday and now today it will not turn on and it is no longer under warranty. I also checked to see if power to plug and it is fine. Any suggestions?
Aug 01, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
474 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
