Question about Car Audio & Video
Leem m86t power mixer amplifier
I have no output from this mixer and the phantom power led stays red condition. I had to fit another power output relay as one was blown contacts. the 2 relays dont seem to be working either . the leds indicate from the mic input but no power output to speaker.
  • 905 Answers
Probably blew the amps or the pre amp section
Posted on Oct 08, 2008
Sir, Iam using the ZED-10FX Allen & Heath mixer. Iam not getting the 48V phanthom power and AUX out from the mixer both Green and RED LED on Phanthom power is not glowing. Iam getting the LED VU m
sOMEHOW YOU BLEW THE 48 v PHANTOM SUPPLY.
Open it up and check power board voltages.
Replace regulator circuit and check for shorts on your mic cables.
PEACE---
Feb 09, 2015 | Allen & Heath ZED-10FX Sound Mixer
When my phantom power is turned on . my condensing mic isnt working . at first i thought it was my mic . but then i got a new one and it still isnt working . what is the problem
HAve you tried a different lead? Try a friends mic that you know works on your mixer. Its usually a process of elimination. You substitute a known working one and see what happens. Is the little LED lighting up when its turned on?
Feb 13, 2011 | Mackie ProFX8 Professional Compact Mixer
I have a rode mic. it doesnt work thru my bhrngr pmx 2000. i have been told i need phantom power. but doesnt the mixer come with that? ric
Yes this unit comes with Phantom power, but you must turn it on. The switch for this is located next to the XLR connector for channel 9 and the bottom of channel 10. Make sure that it is turned on. The LED should be lit with phantom on.
Dan
Aug 26, 2010 | Audio Players & Recorders
Low mic output on BEHRINGER XENYX 1832FX
You don't indicate what type of mic you are attempting to use. From your description, I would guess that you have a mic that requires phantom power. I believe that there is a phantom power switch on your mixer. Try turning that on to see if that resolves the problem. Phantom power will not harm a standard mic. Please update this with your results.
Thanks,
Dan
Apr 06, 2010 | Audio Players & Recorders
Mixer volume LED's do not work
a circuit controls the LED meter. i dont think the LEDs are faulty. the LEDs are connected to this circuit (IC). changing the LEDs wont work.
Mar 14, 2010 | Audio Players & Recorders
Need to know if we can hook a phantom powered microphone to our shs audio amplifier
Does your microphone have it's own built in phantom power? If it's just a regular mic, you should be able to connect into any MIC inputs on your Amplifier. Otherwise, you'll have to utilize a mic/line mixer to provide the phantom power your mic needs. Then you would connect your mixer to the amplifier.
Which SHS Audio amp do you have? The ones that I am familiar with do not have any MIC inputs.
- OPTiC
Master Tech
DJ PRO AUDIO
Pro Audio Equipment : Pro Audio Repairs
Aug 30, 2009 | Audio Players & Recorders
I have a shure microflex mic condencer 150 the led does not work and the mic is dead. Does the mic need a battery if so how do you instal it.
Try using a mixing console with phantom power ( + 48 ). A condenser mic needs 48 volts to operate. The led should light when the XLR microphone cable is connected to a console with phantom power.
Feb 19, 2009 | Shure (LX287CC) Professional Microphone
Get sound through a Behringer 1204FX mixer & FCA202 interface
Block diagram available here:
http://www.behringerdownload.de/XENYX_GRP2/1204FX_VIEW_Rev_A.pdf
Where are the trim controls set?
Those mics use both phantom and battery power; are the mic switches set to phantom?
Try using the CD/Tape outputs to the FCA202
Nov 20, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
Leem power mixer spare part
Have you tried a 2sd6041? sometimes japanese trannys use this prefix.
Sep 17, 2008 | Car Audio & Video
Coleman 1500 power inverter has no output
I believe that the actual unit may have other problems and that you will need a schematic to aid in your troubleshooting of this issue. Once you have the schematic and a multiment you can check the voltages to see if things ar as they should be and then we can look at what is happening.
Sep 01, 2007 | Statpower PW-1750 Triple Outlet 1750 Watt...
Car Audio & Video Logo
479 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
