Question about Intertherm Heating & Cooling
2 Suggested Answers
  • 3 Answers
SOURCE: i have a intertherm fire place in my modular home.
Yes. There is a label just behind the glass, on the right side of the firebox. It says it is intended for wood. (solid wood fuel).
Posted on Jun 29, 2010
Looking for a picture diagram of a Bm36Hc fireplace
[PDF]deluxe 36 manufactured home fireplaces - Hansen Wholesale
36" Wood Burning Fireplaces. P/N 800,019M REV. B 04/2002. BM36HC. BM36HCD..... Refer to the minimum system height chart. WARNING: DO NOT PACK ...Missing: picture
Intertherm BM36HC Installation Instructions Manual > ... > Indoor Fireplace > BM36HC
View and Download Intertherm BM36HC installation instructions manual online. DELUXE 36. BM36HC Indoor Fireplace pdf manual download.
Dec 20, 2015 | Heating & Cooling
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Fan working hot air not coming through front vent
One, is there any air at all coming through the top vent? If not schedule a professional service call with a local reputable company. You may have a blockage. If there is air coming through and it is cool, try letting the fireplace warm up for about 15 minutes before trying to run the fan. The fan can only blow hot air after the fireplace gets hot.
Feb 08, 2014 | Heat and Glo GFK-160A Blower Kit for Heat...
Fan kit will not fit into sequoia opening
You will need to cut back the mortar from the front so you can install the fan kit. If you want to try and do it yourself you will need a masonry blade (diamond blade) on a skill saw and set your thickness on your skill saw to very thin so you don't cut into the fireplace.
Other option is to get a chisel, depending on how much overlaps onto the face, and chip it all back.
You are correct that if you do not get the mortar off of the front to where you can open the front you will not be able to install the fan kit. You can pull up this installation manual at this website
Good luck. Vermont Castings
Jan 11, 2014 | Majestic Fireplaces Majestic FK26 Blower...
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Blade on fireplace heat o lator appears to be turning the wrong way. Heat does not come out of the top of the fireplace. What do I do to be able to take out the heat o later and reverse the fan?
Roger. it depends of whether this is a Gas Fireplace or a Wood Burning Fireplace?
If it's a direct vent gas fireplace, the blower was installed incorrectly. To access the blower, you will have to dismantle most of the interior of the firebox and the burner tray (Interior floor of the firebox). This will involve disconnecting the gas line from the burner. The blower is on the floor of the control compartment and is attached to the rear wall of the control compartment. Whoever installed it, has it aimed in the wrong direction. Which is can of hard to do, since there is an arrow on it, pointing in the UP direction. Once you unplug it, you can take out the sheet metal screws that hold it in place, and it will be quite obvious which way the exhaust should face. Which is UP.
Now that I've told you how to do all of that, I must be totally honest, by telling you, the blower will not increase it's efficiency. Your Direct Vent Gas Fireplace is rated as a Decorative Gas Appliance only. It is not heater rated. In fact, 80 % of all the heat goes out the direct vent. The only real heat, is generated off the glass, once it's hot.
So now, you get the chance to make the decision. With all that's involved, is worth changing the blower and not really gain anything?
If you have a wood burning, brick fireplace Heat-a-Lator, just turning the fan motor around, so that it's pulling air into the chamber, will solve the problem.
I really hope all of this has helped you. If I can be of further assistance please let me know. Thanks.
Jul 14, 2011 | Heating & Cooling
I have a intertherm fire place in my modular home. Model # BM36HCD-BL serial# 6403A05341 manufacture date 01/03. Can i burn wood in this fireplace?
Jan 11, 2010 | Intertherm Heating & Cooling
I am looking for an installation manual for Model FUBSK blower motor kit. We bought a new home and the Lennox Superior wood burning fireplace Model BC-36 has a switch that should force heat out into the...
The fan should be installed behind the bottom grill, and then it should blow air around the firebox which then exits out the top grill. Now saying that, let me explain the actual problem you will face. Because you have a open faced wood fireplace, you will not get the heat your looking for, the fire needs 400 cubic feet of air per hour and that air is taken from your opening. Also the inner box doesn't heat up enuff to produce alot of heat on the skin so if you have the fan blowing full blast, it will only cycle the air and not allow it time to heat up as it cycles around the box. I suggest turning the fan speed down so its 1/2 way on or lower, this allows the air time to heat while cycling around the box, but in the end you still won't have a good heater as the fireplace itself isn't one, you should look at having it converted to direct vent gas or ripping it out and replacing it with a airtight wood.
Jan 03, 2010 | Superior Lennox Blower Thermal Sensor -...
Intertherm Fireplace - Model BM36HCD
Am Looking For same pipe for my fireplace
Apr 26, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
388 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
