Have you looked on your Start>all programs list for stopzilla? Perhaps it is just turned off.
Have you looked in your program files folder for Stopzilla? ( My Computer>C>Program Files>Stopzilla)
If there is not an installation (.exe) file there, then try a search from your search utility just type in stopzilla and click on all files and search. I don't know where you saved the file to originally, so I'm covering a couple of bases here.
If you locate the exe. file then you can just click on it to reinstall.
Please NOTE: Before you do that please go to your control panel (install/uninstall programs) and check the list for stopzilla. If it is there uninstall it, so that you can reinstall.)
Be sure to do a clean install which means to close ALL other running programs including your virus control before reinstalling.
After you reinstall, if you can, then do a restart.
____
If you cannot find the file on your system, then you need to go to
www.stopzilla.com and redownload the file. When you install it will ask for your number and you can type it in. Be sure that if you use this method, once again turn off all running proggys until the install is complete.
Good luck to you.
