Question about Kirby Ultimate G Bagged Upright Vacuum
Sweeper vibrates when pushed forward.
My kirby ultimate G series vibrates or gives resistance when pushed forward. I replaced the rear wheels thinking that would solve the problem but it is still happening. Any suggestions on what is going on and how to fix it?
  • Anonymous Sep 27, 2008
    My kirby is vibrating when pushed forward. I have adjusted height level. Also when try to line up red arrows to engage belt it won't line up. IT just slips back. help??
  • 4 Answers
Do u put it on drive or neutral? does the wheels spin when on drive? is the height adjuster on the right level?
Posted on Sep 09, 2008
It is in drive when I am having the problems and the wheels are spinning. I also changed the height adjuster thinking that was the problem but it still does it regardless of where the height is positioned. I also tried adjusting the roller brush and that also did not help.
How do i replace the on and off switch on a gen 3 kirby sweeper
fault will be cable not power switch, phone your local kirby enginere for fixing
Jul 31, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Kirby diamond vacuum manual download
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
Kirby Series Owner Manual
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 12, 2012 | Kirby Ultimate G Bagged Upright Vacuum
I need to find an instruction manual for the Kirby Ultimate G series Diamond Edition
http://kirbywhq.powweb.com/manuals/UltimateG/77A0CF1A5F7DB07CF87DB5A31B84CF28/UlimateG.pdf
Ava B.
Aug 21, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G wheels lock up when in drive...
Replace the transmission. The tranny that drives these Kirbys can give you problems.
May 16, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to GoodVac.com Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate G .accessory lock is striped. Can that be replaced?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=559479
Kirby ultimate G .accessory lock is striped. Can...
Posted by goulds5 on Apr 30, 2008
Kirby ultimate G My belt broke & sucked into my sweeper & got stuck. My husband had to take it a part, he go out the belt but the accessory lock now is striped. Can that be replaced? Have you ever heard of this?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Yes, the accessory lock can be replaced but it may be part of the actual vacuum head of which could be expensive, it may be molded onto the vacuum head and would be replaced. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How to replace a fuse a Kirby Ultimate G Series
There is no fuse in the Kirby. There are few things that you want to check:
1. Cord - most likely cause. It may not be damaged but wires inside may have snapped if it got between doors.
2. Safety switch inside - no easy way to check. We usually just put a new one in and see if it solves the problem.
3. Motor - very unlikely that something is wrong with the motor - those are very hard to kill.
Apr 20, 2008 | Kirby Heritage II Vacuum
Kirby heritage 2 sweeper
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
the above link shows you how to change the belt on the g-series kirbys but it will apply to the heritage edition as well...the only difference is the color...some of the arrows may be missing on the front belt lifter knob...but they are little differences...
hope this helps!!!
Feb 06, 2008 | Kirby Heritage II Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
191 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
