Question about Palm Vx Handheld
Serial USB connection to an old palm
I got an old palm vx with serial outlet, in my laptop there's only USB inlets I got an adapter but my laptop still wont recognize the palm And I cant do synchronization?.. HELP!!
    Champion:
  • 277 Answers
This is a common issue, you might want to try these, in hope 1 of them will work: - make sure there's no problem in the configurations of the devices and their both connection is to USB. - there's probably a collision with anther device that is connected to the palm, try doing uninstall to everything, do a hard reset, run " activesync" or " hotsync" and reconnect. - there's maybe a problem in the drivers, try reinstall them. - if you are using 3.16 pm, there's probably a collision
Posted on Feb 23, 2006
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
http://www.startech.com/au/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
https://en.wikipedia.org/wiki/Null_modem
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Trying to connect a lap top to the 450C designjet but don't have the proper connection to hook up
I believe this plotter has both the old centronics and a 25 pin serial connection. Your laptop MAY have a 7 pin serial connection which you can get a 7 pin to 25 pin serial cable. If your laptop does not have a serial port, you MIGHT find a USB to serial adapter cable.
Make sure you are not on Vista or Win 7 operating systems as they likely do NOT have compatible drivers for this plotter.
Jan 13, 2010 | HP DesignJet 450c InkJet Printer
USB data transfer from old to new computer
I answered you in another post, you need to network the computers via ethernet, not USB.
Jan 29, 2009 | Micro Innovations MCNCPQ5PHC USB PCI Card...
Pfaff 7570 connection to new XP laptop
In this FAQ list (from PFAFF web) you find 100 times the same question and answer:
H402 My new computer does not have any serial COM ports, so how does it communicate with my Pfaff creative 7570?
You will need to obtain a USB Serial Adapter, which adds a serial port to your computer by plugging it into a USB port. Suitable adapters can be obtained from Belkin [http://www.belkin.com] and Keyspan [http://www.keyspan.com].
The following USB Serial Adapters are known to work with the Pfaff creative 7570:
• Belkin F5U103
• Keyspan USA-19QW
Please note that the Belkin F5U109 is listed as working with the Pfaff creative 2140/2144 (FAQ #H405), but it does not work the Pfaff creative 7570.
Jan 06, 2009 | PfaFF Creative 7570
F5u109 Serial USB PDA Adapter.. Need Drivers for XP
calling you no. I am a belkin partner. are you needing drivers for the usb device
Feb 11, 2008 | Belkin USB PDA Adapter [ F5U109 ] (109198)...
Can't connect my Bernina 170 Embroidery unit to my computer
I just bought a new laptop and upgraded to V.6. Since I have always used a magic box I didn't know how to attach my bernina 170 directly to the laptop. My bernina dealer said that I would first need a serial to usb adapter since my machine is old enough that it doesn't have a usb port on it. Make sure it doesn't have the screws on the serial part because they will not allow you to attach it to the machine. He also said that I may have to make a new com port as most pc laptops only show 4. I did a search of the computer and found how to make a new com port. A little more fiddleing around with the laptop and cables and restarting both then it somehow recognized that I had made a new com port. Voila. It now works. (I am a Mac person). Hope this helps. margaret
Jan 04, 2008 | Bernina Artista 170
Connecting serial with USB
I think it?s a common problem. You?re welcome to try the next options, in hopes of one of them working out: 1. Make sure there is no problem in the settings and that in both computers the connection is set to USB. 2. There may be a clash between this connection and another component that is connected to the Palm. Try uninstalling everything, hard resetting and running Hotsync or Activesync, and reconnecting the units. 3. There might be a problem in the drivers, try reinstalling them. 4. If you are using PM 3.16, there might be a clash.
Feb 22, 2006 | Palm Vx Handheld
Connecting old palm vx with serial output tought usb
Hi, Few Things that you may do to fix this problem: 1. Is the "Local Serial" checked when you click the hot sync icon in the PC tray? 2. Look for ?hotsyncheck? at palm.com maybe this can help. hope this will help' Daniel
Feb 09, 2006 | Palm Vx Handheld
Connection is lost (6410)
First open the HotSync custom menu, start changing conduits to do nothing. Work your way down the list until you end up with a complete HotSync. If you still have the 6410 error, unplug the USB adapter, replug and try your HotSync again. The USB adapter may be the week link in this equation.
Sep 12, 2005 | Palm IIIe Special Edition Handheld
Palm Vx Handheld Logo
46 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
