Expert
- Posted on Aug 26, 2011
Re: How do you put the batteries in?
- Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS)
and remove at least 1 battery from each column of batteries. After 2-5 seconds,
reinsert the batteries and turn the unit on. This will cause the unit to reboot
the operating system.
- Remove the keypad (for TI-Nspire Family or TI-Nspire CAS Touchpad) or the
battery door (for TI-Nspire CAS) and remove at least 1 battery from each column
of batteries. After 2-5 seconds, reinsert the batteries and LEAVE THE UNIT OFF
(do not turn on and then back off). If the TI-Nspire/TI-Nspire CAS is
a Clickpad, hold down [Home] [Enter] [P], and while holding these keys, press
[On]. If the TI-Nspire/TI-Nspire CAS is a Touchpad, instead hold down [Doc]
[Enter] [EE], and while holding these keys, press [On]. The device will boot up
as in the previous reset, but will display a menu with the following options.
Please try options 1, 2, 3, and 4 in that order. ** The [Home] key is located at
the top right of the TI-Nspire keypad and has a picture of a house on
it.
