Question about Stanley Air Tools & Compressors
Bostitch air compressor cap 60p-of
My compressor is not hold air. it will only get up to 20 psi and does not go past that. help
  • Anonymous Mar 14, 2014
    need to replace belt bostitch air cmpressor cap2000p-of cover off how do i get the piston shaft off to install new belt
  • Anonymous Mar 30, 2014
    won't compress beyond 20 psi
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Mine had the same problem.
One of the reed valves in the head had broken off due to metal fatigue. Take off black plastic housing with 5 screws along the bottom and one bolt under the handle (the front only). Unscrew the four allen headed screws on top of the compressor. Unscrew the discharge line from the head. You'll need part # AB-A640050 which is the valve plate assy. and possibly AB-9007012 which is the intake valve located in the top of the piston (if damaged). About $18 including shipping from Bostitch.
Posted on Dec 16, 2008
  • artgalnj Jan 18, 2011
    Had the same extact problem with my compressor. It would get as far as 80 psi and not go up any further and the motor kept running. LaMojoe was correct. The metal was erroded on the valve plate assembly and thus allowing air to flow through.
  • 59 Answers
Turn the gauge up to allow more air or try checking the drain plug on bottom of tank to see if it tight.
If these 2 don't fix it check all connections for leaks.
Posted on Sep 18, 2008
Motor turns and pump pully does not. burning up belt.
Air Compressor Trouble-Shooting, Problems, The Causes ...
www.portlandcompressor.com/compressor/trouble-shooting.aspx
Provided below is a general list of common air compressor problems, and a few quick ... Loose pulley, flywheel, belt, belt guard, cooler, clamps or accessories. ... Piston rings installed up-side down. ... Receiver does not hold pressure when compressor is unloaded. ... Turn on power, check fuse, breaker, or motor overload.
Reasons Why an Air Compressor Will Not Build Pressure
fix-my-compressor.com/compressor-will-not-build-pressure/
An air compressor that will not build pressure runs on long past the point where it normally ... air compressor with at least one piston that moves up and down or side to side to pump air - cycles, .... I have an Ingersoll rand 7100 compressor 2stage 175 psi 120 gal tank ... The motor is a 2.5hp 3450 rpms with a 4 inch pulley.
Supercharge your Air Compressor for 20 bucks or less - Sawmill ...
www.sawmillcreek.org > ... > General Woodworking and Power Tools
Mar 16, 2006 - 15 posts - ‎8 authors
I have a 27 gallon belt driven Sanborn (Coleman) compressor and I have been ... I'mnot suggesting they won't compress air or give good service. .... Most any small oil-less compressor will serve a nailor, pump up the snow tires ... A two stagecompressor pumps 20 to 30% more CFM per motor HP thanks to ...
Jan 05, 2016 | Ingersoll Air Tools & Compressors
Well picked this up at a auction and i need to get some part like the air filter and the air filter holder plus a new dip stckalso the manual.. plus i need to know why it won't charge past 50 psi
compressors that do not go past 50 psi generally have a failed poppet valve or reed valve in the heads of the compressor
talk with a compressor repair shop for the filters and housings and where you can get the valves and gaskets
Oct 26, 2015 | Psi Air Tools & Compressors
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
Why will my bostitch pancake compressor 240 psi tank 180 regulator that the guages will not show building pressure
Hi, There are different posibilities. I would need more information. Was it always like that? Does the guage on the main tank and the guage on the regulator both not show more than 20psi? When the auto shut-off is triggered do you feel there is more than 20 psi in the tank?
Sep 15, 2014 | Stanley NEW Bostitch 2 HP 6 Gallon...
My sears air compressor model 919.156781 will not pump up past 40 psi , then motor then compressor stalls and motor gets hot , have to unplug . I have had the motor checked
When it gets to 40 psi turn it off and see if you hear air leaking down from somewhere....if so listen and feel around the edges of the compressor head. If you hear or feel air leaking there you may need to replace a head gasket.
Jun 13, 2014 | Craftsman 20 Gallon Portable Horizontal...
Searching for fenwai pressure control fw 10
If your compressor is a piston compressor, try cleaning the check valve which comes from the pressure switch to the tank (it has a little spring and a rubber/plastic valve inside)
Otherwise check to see if it is sucking air in properly, (whilst it is running, remove the air filter, and very quickly put your hand over the air intake to see if it is sucking whilst it is at 20 psi, if not, then it may be that the valves in the head maybe either broken or not seating properly
If it is not a piston compressor, then it maybe the MPV needing some attention
Hope that helps
Aug 22, 2012 | Air Tools & Compressors
Craftsman model no. 921.153101 won't go past 20
check the pressure switch also is it before or after a regulator
Mar 22, 2012 | Craftsman Air Tools & Compressors
Pressure does not go past 20-25 PSI
Hi
Perhaps it may be something to do with the setting of the pressure valve
Cheers
John
Jun 26, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Would not pump past 90 pounds psi, now does not pump at all
Might be a switch failure. Usually the switches will have an integrated pressure switch to shut the compressor off when the holding tank reaches its max psi. When the switch starts to malfunction, it will shut the compressor off early and eventually fail due to overheating of the internal components of the switch.
Sep 23, 2010 | Air Tools & Compressors
Air Tools & Compressors Logo
1,819 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
