Question about HP PSC 1110 All-In-One Thermal Printer
"Incorrect black cartridge"error
Recently when I print I get the next message "black print cartridge is wrong kind for this device" The ink cartridge is the original and I have already printed with it about 100 pages In advance a led is flashing that says "check printer cartridge" every time I start the printer I've tried pulling it out and reputing it but with out any changes Please help
  • Anonymous Mar 21, 2014
    i have already changed 4 to 5 cartridges in a month
    Champion:
  • 277 Answers
This message appears also when the head is the right 1, but the connectors are dirty Try this solution ? fill a flat bowl with warm water (not too hot!!) For about 3 millimeters and put the ink head inside so only the connectors will be in the water for about a minute or two Wipe the whole head well, try cleaning the connectors a little and reassemble it Good luck
Posted on Feb 23, 2006
  • Richard Woodcock
    Richard Woodcock Jan 26, 2014
    I tried his on MP560 printer and still receive error message U052, anyone find something that really works
Does not print evenly. Some lines are very faint. Have done calibration and cleaned print head several times. Prints from internet and e-mails okay. But does print from Simply Accounting, tax software...
Welcome to FixYa.
Since you have already performed calibration and cleaned the printhead, kindly verify that the ink cartridges are not damaged and are completely seated in the printhead:
1. Lift the printer access door, then remove the ink cartridges from the printhead.
2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
3. Verify that the KODAK Ink Cartridges have not been refilled.
4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
6. Close the printer access door.
7. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
NOTE: When the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
8.Reprint the original picture or document that had the quality problem.
Hope this helps. Thanks for using FixYa.
Dec 15, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Check ink u163 error message
Firstly I suspect you are not using genuine cartridge or you have refilled the cartridge.
To fix this you need to disable the ink checking procedure.
Do you know that low ink or ink has run out message appears once cartridge empty. If you want to use refill ink in that cartridge then you need to deactivate ink level to get your printer run as usual. Check the following tips to fix low ink error message in case of refill ink usage. Below some methods to deactivate ink level detection function for some models due to its similarity.
METHOD I:
Press RESUME/CANCEL button once
Related models:
BJC series: bjc3000,8200,etcS series: s400,600,800,6300,9000etc
i Series: i255,320,350,355,450,470d,550,560,850,950,6100,6500,9100,etc
Pixma series: ip1000,1200,1300,1500,1600,1700,2000,2200,3000,4000,etc
METHOD II:
Hold down RESUME/CANCEL button for 5 seconds or more
Related models:
Latest models of Pixma series: ip1880,1980,3300,3500,4200,4500,5200,6700d,pro9000,9500,ix4000,5000,etc
METHOD III:
Press START button once, select COLOR button for colour cartridge; BLACK button for black cartridge
Applicable models:
Pixma MP150,160,170,180,450,460,475,etc
METHOD IV:
Hold down STOP/RESET button for 5 seconds or more
Applicable models:
Latest models of Pixma MP/MX series: MP145,228,245,520,800,850,970,MX308,318,7600,et
Jun 21, 2009 | Canon MX300 Office All-In-One Printer
Lexmark 6570 "out of ink error message"
I have a Lexmark printer too, and after my original Lexmark ran out of ink, I bought some off of eBay (off brand, not original Lexmark ink), and I get the message I am not using original Lexmark ink, and it is not covered by warranty.  There is no way to remove this message, unfortunately.
May 26, 2009 | Lexmark X6170 All-In-One InkJet Printer
PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Sep 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printing is crooked on the page...otherwise prints beautifully
Sounds like the print head / ink cartridge is not seated all the way. Open the door and check it. It also may be the wrong print head / ink cartridge. If you replaced the print head / ink cartridge recently, you may have the wrong one for your device. If it is a off brand or refilled print head / ink cartridge it may be damaged or incorrectly identified.
Jun 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Just replaced my black and color cartridges with new lexmark...
Hi tfonts,
This is normal behavior for proprietary print devices if you have not provided them with a new print cartridge and have instead filled them yourself.
Terry
May 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
Newly Installed 7680
probably you did nothing wring, I seen a few of these cartridges leak - HP should replace the machine if the damage was caused by original cartridges.
Apr 21, 2008 | HP Officejet Pro L7680 All-In-One Printer
We just attached the macbook to the hppsc 1350v all in one printer and new print cartridges. When attempting to print, message reads"color print cartridge not compatible with this printer". We know we have...
Just to confirm pls:
1. the new print cartridges are original HP inks;
2. you have remove the bright pink tape from the ink cartridges;
3. the black is on the right side and the color is on the left side.
You can try removing both cartridges and clean the gold colored contacts where the pink tape was. Pls do the same to the mate pins in the cartridge holder in the printer.
Try again. If this does not be corrective, you may need to change inks again.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 02, 2008 | Computers & Internet
Error message ?incorrect black cartridge?
You can get this message even when the cartridge is the right one, but the joints are covered in ink. Try the following solution- fill a bowl with hot water (not boiling hot), 3 mm high, remove the cartridge and place it so only the joints are submerged in the water, for a minute or 2. Dry it well, clean the joints again and place it in the printer. Good luck.
Feb 22, 2006 | HP PSC 1110 All-In-One Thermal Printer
HP PSC 1110 All-In-One Thermal Printer Logo
152 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
