Frigidaire FAC126P1 wall/window Air Conditioner Logo
Posted on Aug 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a goldstar air conditioner thats throwing water
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Aug 26, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2105029
Points
14643
The problem you're having can be the result of 2 tings.
1. The drain hole in the drip pan under the unit is clogged. The hole should be located near the rear of
the unit. It can be hard to find at times, as the clog will bled in with the hole.
2. The rear of the unit does not have enough downward tilt. Which allows the collected water to flow to
the drain hole. The general rule of thumb is 1/4" to 1/2" downward tilt at the rear of the unit.
Hope this helped you and thanks for choosing FixYa.
3answers
How to clean a Goldstar 6004 air conditioner
https://www.thespruce.com/how-to-clean-a-window-air-conditioner-unit-5191162
1helpful
How do I stop my Air conditioner from throwing a mist inside the room?
Cleaning the air intake filter and the cooling coils will help. But, as long as there is high humidity outside, the unit will continue to mist to some degree.
Hope this helps you and thanks for choosing FixYa.
My A.C. unit is not cooling my room like it was a couple of days ago it just throws out air that is not cold and when I turn it on it the air that comes out on cool mode is like the air that comes out in...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
My goldstar window air conditioner keeps spitting water out of the vents and making a loud noise, what is it? Please.
Hello
Could be the drain hole is clogged up outside.
Its usually located on the bottom r h side.Needs to be unclogged.Use a thin piece of wire or compressed air or even a good blast of water to fix it.
1helpful
Where is the drain plug on this unit goldstar 6500 airconditione
There is no drain plug,if it is not draining,then the drain holes are stopped up with trash and debris,remove the unit from the window,and take it out side,use a water hose to clean it out,and you will be fine,if this was at all helpful,please rate,thank you.
1helpful
What if the air conditioner is not dripping the water out the back
If the humidity is not high youwill not gget much water out the back. The air conditioner has slinger ring on the condenser fan than throw the water onto the coil and it is evaperated. Rus
1helpful
Goldstar 10000 blows water out front
Two possible problems.
1. High humidity in the space being cooled
2. Drain line that runs from the front (where the water is blowing out) to the back where it is sent to evaporate. Clean out the drain line and condensate pan under the fins where the water is blowing out.
1helpful
Sounds like fan is hitting water, also throwing off a water mist.
Look outside the unit, unless you are very high in the air and clean out the condensate\water drain hole. You live in a very humid climate, you have to keep that hole clear or water will build up. Some units us a splash system to splash on to the condenser to help cool it.
Goldstar R1804H
well u should take it out the window and dran the water out unite thwe water is gone then put it back ang if u still see that its freezing try it again and then put it one and u my have to do this offin to keep it from freezing
Top Frigidaire Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
