Question about Panasonic AG-DV2000 Mini DV VCR
F4 error message
Machine runs for about 3 seconds and shuts off. The tape will not eject.
  • brian1378 Mar 11, 2009
    I have a miniDV tape stuck in the machine and it won't eject.  It makes a sound like the tape is loading or about to play and then it stops and turns off.  The error code F 04 displays on the read-out.  Any advise?  brian1378@hotmail.com  Thanks.
  • starvideo2 Mar 25, 2009
    Tape will not eject. F4 error message on. Tried unplugging, flipping
    the eject button several time (worked in the past), but NOTHING will
    work to eject tape.
2 Suggested Answers
SOURCE: Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Posted on Jan 20, 2007
jmgldsmth
  • 1869 Answers
SOURCE: Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
Posted on May 21, 2009
Does not eject
Best to get the service manual, this will explain the best way to get the tape out of the machine without causing further damage to the drive system.
However if you can't find it, take the top off and remove the tape very carefully. Try and determine how the tape can be removed without force, possibly by moving the mechanism by hand.
The video shuts down to prevent the problem causing further damage.
Feb 04, 2014 | Fisher FVH-4913A VHS VCR
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Keeps going to "err" and shuts down when I insert tape
Hi. your VCR is experiencing a major mechanism fault within the head assembly. the head is unable to read the tape. in this case, you will need to replace the main head assembly in this unit.
May 18, 2009 | Emerson VCRs
Help needed for tape in machine and error message
most likely problem is bad capacitors on the mechanical interface board.
Sep 09, 2008 | Panasonic AG-DV2000 Mini DV VCR
Power problems on VCR
When a tape is inserted or ejected the machine will attempt to tighten the tape by turning the rewind hub for a second, then it watches the counter to see if the fast foward hub turned (thus the tape is tight), if the tape can not turn or the counter sensor is bad then it shuts off (a safety mode to prevent tape damage). So, you could have a bad belt, bad idler wheel, or bad sensor.
Hope that helps...
Geno
Mar 26, 2008 | VCRs
Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Mar 10, 2008 | VCRs
Sharp VCR Model VC-685U
Actually the problem is in the capstan drive. If you replace or clean the idler, the problem will likely disappear....accordianman
Feb 15, 2008 | VCRs
F08 Error message, keeps shutting down
Get it to a shop. The error is a drum servo related problem. Don't force the mechanism or you'll be out even more...accordianman
Feb 15, 2008 | Panasonic AG-DV2700 Mini DV VCR
VCR tape playing error
It needs its belts replaced
Dec 29, 2007 | VCRs
Error Message and tape is hung up on the drive mechanism.
check the drive belts in both decks. they stretch with age.
Nov 07, 2007 | Rio Go Video GV6060 Dual Deck VCR
Panasonic AG-DV2000 Mini DV VCR Logo
128 people viewed this question
Top Panasonic VCRs Experts
Pieter Vleeshouwers
Are you a Panasonic VCR Expert? Answer questions, earn points and help others
