Question about Ovens
Oven doesnt heat up
I seen a spark in the oven now the oven doesnt heat up the fan still blows cold air the grill works and so does the top can u tell what needs done thank u
    President:
  • 1,462 Answers
Remove back panel inside oven and element will be exposed. this element is probably faulty and you can often see the damage
to replace, take the outer rear panel off and element fixings are in view - easy job usually
Posted on Sep 09, 2008
Electrolux EOB5630X. Oven works fine for about 20-30mins then cuts out (light in oven turns off and grill will not work at this time either). Will work fine again after temp in oven cools but cuts out...
the electronics are heating up and cutting out.that cold be a bad clock assy. or there's a fan in there that could be bad or i've seen on some models there's a screen in where the fan is,it gets clogged with dust and the air can't blow to cool down the electronics.if it is the fan and you keep using it like that it will take out the computer board or clock assy. same part.
Nov 13, 2017 | Electrolux EOB5630 Ultrafan Electric...
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Fan not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 12, 2010 | Zanussi ZBQ665 Electric Single Oven
The fan in my oven is blowing out cold air and while the convention oven is working- it takes a long time to heat up and doesnt cook food as well as the fan assist
Candy Oven not heating? How to replace a Candy fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for element How to Repair Home Appliances
Dec 11, 2009 | Candy Ovens
Grill is working but oven wont heat up
You need to replace the oven element, it is located at the rear of the oven behind a removeable panel.
Please rate my sol;ution.
Thanks.
Nov 17, 2009 | Belling XOU252 Electric Single Oven
My whirlpool fan assisted oven is not heating the fan is blowing cold air out, my gril and my hobs work fine
Sounds like you need a new fan element. You'll need to quote your model to ensure you get the correct element. A lot of Whirlpools can be done from the inside so the oven stays in the housing. Don't forget to power off first though! :)
Jun 21, 2009 | Ovens
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Smeg oven
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
Ovens Logo
142 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
