Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
When I use the remote to power-on my tv,the power light comes on for about 3 sec...and then it will turn off for about 3 sec. Then it will turn itself on again for about 3 sec. and then it will turn
When I use the remote to power-on my tv, the power light comes on for about 3 sec...and then it will turn itself off for about 3 sec..Then it will turn itself on again for about 3 sec. and then it will turn itself off again for good.
the same thing happens when I use the power button.
  • z0na Sep 09, 2008
    I have exactly the same problem. The power lights comes and go for a few moments, but no any sounds. Tv remote can't do nothing. Before this happened, when I set my tv on, it had some short lasting, multiple horizontal lines. Now, I can't turn my tv on, at all. Please help me out.
    Problem Solver:
  • 39 Answers
Probably vented caps, or high voltage circuit failure. Sugg, replace tripler.
Posted on Oct 02, 2008
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
Samsung LCD TV 26
If you have not tried it you may want to see if the voltages listed come up with boards disconnected from the power supply one at a time---This could be anywhere from micro to the panel.
Mar 25, 2012 | Televison & Video
Tv Turns on for 3 sec.then turns off Remote RM-Y914I know it's the remotecontrol
remove the batteries from remote and try turning the tv on manually and see if it still does it. if it does then your tv probably has a bad part in it and your tv is turning off in fear of overheating, must be looked at with a local repair shop.
May 11, 2010 | Sony RM-V310 Remote Control
I have a Zenith TV and need to reprogram my remote.. thank you for the rca ones,,
OK if you need remote code try this:
11423/10017/10463/11265/10145/10092/10030/11145/10016 .OK need how point your remote to your TV then press & hold on remote TV button at the same time remote power button until solid light come up then press & hold play button for 5 sec until TV sleep then press and hold reverse button for 2-3 sec until your TV light up if yes press stop button.
good luck.
Apr 28, 2010 | Universal Remote Control GE174Universal...
CANNOT PROGRAM REMOTE TO NORCENT TV
hi are you use universal remote if yes let me think that u use RCA UNIVERSAL REMOTE do this press and hold on remote the TV button at same time press and hold power button on remote solid light until come up then press N HOLD play for five sec until your TV sleep then press and hold REVERSE EVERY 2 SEC until your tv comes up then press stop, do all that when you are point to your TV . good luck.
Apr 28, 2010 | Norcent Technologies LT4247 42 in. LCD TV
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
Blue light
2)wait 10 sec
4)wait 30 sec
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Nov 27, 2008 | JVC LT-42X579 42 in. LCD TV
Help!
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
May 03, 2008 | RCA RCR412C Remote Control
Using a Jensen remote, can't access input mode
turn on your tv, press and hold tv button, then the on/off button, it will light up then press the power button.and it turns off....hold. After holding down both for buttons for 3 secs the light on the on/off key turns back on. Release both keys and the light should stay on. Now hit the On/off button repeatedly until the tv turns off, when it does hit the stop button to save code.
Apr 03, 2007 | Jensen 143307 Remote Control
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
152 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
