Using fan relay to ad a/c to mobile home
What do you mean the n/c switch hooks up to the heater box
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Remember a fan switch has 2- contacts pus coil power (24volts) a normaly open --and a normaly close thus n. o. contacts and a n. c. .. contacts and and you hook the 24volt coil contact to cool and the hi-speed fan switch to the n.o. contacts... SO when it don't calls for cool the n.c. contact wil send power to the low speed wire for heat (red to the fan motor which connects to the temperature control which cycle on the fan when calling for heat! HEY, you didn't give enough information, like WHAT___WHERE___WHEN__WHO ??? ____ model #-- name of unit-- age-- gas fire or electric ---upflw or downflow?
Posted on Sep 09, 2008
Heater fan keep run even iggnition is off
The relay is stuck. Access your fuse/relay box and look for a relay labeled as heater or blower motor. Remove the relay.the fan should turn off if you have the correct one. Use a test light to check for power. You should have power at only 1 terminal when the fan switch is off. If so, then replace the relay. If there is power at 2 terminals then the switch or wiring is shorted.
Mar 01, 2016 | 2008 Mercedes-Benz ML 350
Fan relay location
what vehicle ?? usualy in fuse box under hood some are on or neer rads or do you mean heater fan the will be under passenger side dash in the heater box follow wires back from the heater motor they are attached to the relay some are real pain to get out
Aug 15, 2014 | Cars & Trucks
Water feature pump will not work,so i hooked it up to main pump switch and it works does that mean i have a bad relay in box
It could mean that but it is hard to say. You should check the power in and the power out of the relay. Or if you have an open spot on your panel plug the relay in to that one to see if that trips it.
Sep 22, 2010 | Jandy AQUALINK RS TELELINK KIT
1999 Mercury Mountaineer, heater/AC fan no longer blowing
I would check the fan first disconnect the electrical connectors on it and use a pair of home made jumper cables and run it from the battery. If it works move unto relay if it doesn't you've found the culprit.
Next check relay in the fuse box. Coolant tempertant switch(CTS) aka thermal switch and its circuit. CTS is usually located in the water jacket by the t-stat.
Apr 05, 2010 | 1999 Mercury Mountaineer
Heater stops.fan still runs.
Most furnaces are equiped with a two speed blower. Hi speed is controlled by a relay sytem initiated by the thermostat. short of a stuck relay, hi speed should not remain on unless your thermostat "fan swith" has been moved from "auto" to "on", if this is the case turn the switch to "auto"
Low speed is controlled solely by the furnace itself. Depending on the age and brand of the furnace it is either brought on by time or temperature.
From your description of "tapping the relay of the limit switch" I assume you have an older furnace with a combination fan/limit control. The most common of these were a grey box with a removeable rectangular lid. In some cases there was a (commonly white) switch poking through this cover which you could manually turn low speed on if you pushed it in, make sure it is pulled out.
Otherwise the switch is refered to as a bi-metal limit. When heated the two dis-similar metals (coiled together) expand and contract at different rates. When the furnace cycles on, the metals heat and, due to design, twist a dial, which you should be able to see under the rectangular lid. The dial should have three pin settings for the purpose of switching. the lowest setting, usually around 105, is the fan OFF setting. The second, usually aroun 135, is the fan ON setting. The highest should be fixed around 250 it is the high limit and should not be part of your problem.
....After your thermostat has been satisfied and the flame shuts down...you can physically watch that dial move clockwise and hopefully reach the setting of around 105, unlesss that setting is set below the temperature of the room the furnace is in (try setting this setting higher to see if it helps).
(make and age of furnace helps a lot with trying to trouble shoot, also is it a mobile home unit?)
Dec 28, 2009 | Coleman Propane Forced Air Heater...
I have a Coleman Presidential 7670 furnace in a mobile home. customer said it came on a couple of times by itself. I ran new wire, fan won,t shut off. Replaced fan switch, fan still won't shut off....
Brian, it sounds as if possibly the fan relay is stuck however, if the fan will not shut off I would suggest the following, Follow the wires from the fan to the relay on the relay disconnect the fan wire there and see if the fan shuts down if so there is the problem. If not you possibly have a short in the thermostat wire What can be done is take a small section of thermostat wire and disconnecting the existing thermostat (red 24 v power feed, green, is fan motor control, yellow is compressor control, white is heater control,) once you have disconnected the existing thermostat wires take the short peice of wire and connect it to the terminal block, once this done the other end (do not hook the wiring to a thermostat have the wires bare at the ends about 1/4 inch) Manually connect the red and green wires togather and see if the fan activates. If it does disconnect the r,g wires if the fan still runs then the fan relay is stuck, if not then it sounds as if there is a short in the wiring between the thermostat and the terminal block. Also check to make sure that you have set the thermostat setting itself to either gas or electric since the newer thermostats have the option of being used as gas or electric. Good Luck on your repairs.
Dave in Texas
Sep 01, 2009 | Heating & Cooling
I can't find the heater fan relay on my 1991 Honda Accord EX 4 dt
you mean the cooling fan? for the rad the relay is under the hood by the battery in the fuse and relay box
Feb 19, 2009 | 1992 Honda Accord
Locating temperature relay
relay is attached to heater box under dash on passenger side under plastic cover,first remove vacuum motor (diaphragm) for fresh air door.
Sep 10, 2008 | 1990 Jeep Cherokee Limited
I need to add a/c to mobile home using a fan relay
OK< the n/c switch hooks up to the heater box so when the heat close the box switch , youll have power to fan.. The n/o contact connects to highfan (black wire) & the 24 volt yellow wire connects to one side of the fan contacts and the other to common!
Sep 07, 2008 | Heating & Cooling
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
