Question about MSI CR52-M CD-RW Burner
The burner wont except the media even when its without any data Left button blinks for a while then shut off In normal condition the right button (open\close) is on permanently after identifying the media when its ready for burning and so? What's the problem and how can I fix it?
    Champion:
  • 277 Answers
Try updating the drivers from: http://www.msi.com.tw/program/support/download/dld/spt_dld_detail.php?UID=500&kind=5
Posted on Feb 23, 2006
Lable print ran out for paper and will not go back to normal. The lights on top are all on except Data , and is blinking Error Condition, Print Idle, Error cleared head open on the screen.
check the setings, change the setings, Media TYPE from Termal Transfere to Direct Termal.
if necessery, reset the printer to Factory Defult.
Mar 31, 2010 | Zebra Z4Mplus Label Printer
Hi Can you help... we have the hp 450c and the media will not load, the cartridge, data, and media light stays on and then when you hit cancel the align media light stays on. Thanks Jill
This is an old posting so you probably have come right already (or thrown the plotter away) This fault is one of two things, firstly it's probably the carrage is likley sticking, clean the bar (silver bar( that runs from left to right with turpentine or spirits, you then need to lubricate it with sewing machine oil or similar. Spread the oil evenly across the bar by moving the carrage by hand left and right, use no more than two drops of oil. Also chack the condition of the belt and make sure it is in good condition. Secondally it could simply be a faulty black cartrige, try and replace and see what happens.
Regards
Dave
Feb 18, 2010 | HP DesignJet 450c InkJet Printer
Desktop DVD fails to recognize "commercial" DVDs
Hello my friend,i can think only 2 things.The first thing is the region code.So right-click My Computer then select Properties,select the Hardware tab,click the Device Manager button and go to DVD/CD-ROM drives,double click to open the tree.Then choose your dvd burner and double click or right click and properties to open the dvd properties.Go to the dvd region code and select the code/country that the dvd supports and click OK.Also you can download a program called region free.The second thing is that your drive supports CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD+R DL, DVD-R DL, DVD-RAM so if the disc is something else then is not supported by your reader/burner.
Feb 08, 2010 | LG GSA-H55N DVD-RAM Burner
1998 buick park avenue turn signal problem
if the right side blinks normal, the flasher MAY be OK?? do the hazard lights flash all lights?it should. make sure you have all the correct bulbs. if so, replace the flasher unit. if the right side works turn it on and follow the ticking to find th eunit.
Oct 06, 2009 | 1998 Buick Park Avenue
Startup logo appears then it goes to a black screen and blinks
You should try booting into safe mode. Press the F8 key before the windows logo and choose safe mode without network support. If windows loads run a checkdisk by right clicking on the c drive, left click on properties and then select the tools tab. From there you can run a disk test to check for errors. If you get that far then reboot and see if it starts normally. If not try F8 again and try selecting restore the last known working condition. This will restore your settings from the last time it worked. If you can’t get to the F8 screen get back with me and I will try a few more drastic solutions. Good Luck
Jul 22, 2009 | Computers & Internet
"normal cycle" light keeps blinking
The blinking button indicates the button is bad. The button console will have to be replaced.
If you need further assistance, let me know
Regards,
reg501
Jul 11, 2008 | Whirlpool 24 in. DU1050SS Built-in...
My becket honeywell r7184p oil burner monitor is not resetting it keeps blinking a fast green. What should i be looking for?
my Beckett oil burner with a honeywell R7184P just did the same thing. Quit burning, blinks for half a second. The burner says press reset once, if it does not reset then call a local serviceman. It is cold here in Alaska, you betcha', and my oil must have jelled up. It happened once, but pressing reset solved my problem, two days later it stopped again. I applied heat (hair dryer) to my supply line, added an anti-jelling solution to my tank. Here is what I found.
"The Honeywell R7184P-1080 (interrupted control—transformer shuts down 10 seconds after flame is established) is now the standard control used on all Beckett oil burners along with the new “Cleancut” pump. The Honeywell control has both a 15 second pre-purge and a 15 second post purge feature, as well as internal self-checking of the control itself. The control has 15 second lockout timing plus a 10 second ignition carry over period. After 3 lockouts during the same call for heat, the control goes into restricted lockout., A restricted lockout condition may be reset by holding the reset button down for 30 seconds until the LED flashes twice. At any time the control is powered, the reset button may be held for 30 seconds to reset the lockout counter. There are several new “Service Features” with the R7184P control that make for easier servicing."
You have to press the reset button for thirty seconds. I don't know how cold it it there, or what number oil you guys are burning, but what I do know is that you guys have been pressing your reset button more than once.
This worked for me. Good luck.
Jun 12, 2008 | Heating & Cooling
Lg dvd
Check whether your DVD's that makes the media player to stuck. If those disks are scrached,it makes the ROM difficult to get data from it and when stucks at one point the ROM goes on trying get that the data at that point even thought it's immpossible.This causes the player to Freeze.Need More help?
Mar 07, 2008 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
MSI CR52-M CD-RW Burner Logo
Top MSI Computers & Internet Experts
Alun Cox
Computer Links
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
