Question about Coleman Heating & Cooling
BURNER WILL NOT COME ON - Coleman Heating & Cooling
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
What are the 4--W's (WHO__WHAT__WHEN__WHERE? or name brand--model #-- serial #'s oil fire---or gas fire--- up flow---downflow ----age of unit--- piot light or hot surface igniter ect. ect...
Posted on Sep 09, 2008
How to fix la germania burner?
Guess you mean a kitchen appliance not a cd/dvd burner! The only way to help you giving some advice about how to fix ut is if you tell us the problem you need to fix.
Describe your burner: is it a gas burner or an electric burner?
Had you repaired something similar before?
In any case, watch some youtube tutoriasl to repair a burner
Cooktop Range burner not heating burner light is on GE Hotpoint RCA...
GE Hotpoint RCA Gas Stove Repair Burner is not working JGSP44BEY3BB
Prego Project Fix GE Stove Burner
Stove Oven Range Burner Repair Diagnostic GE Hotpoint Kenmore Sears RCA...
Aug 19, 2015 | Computers & Internet
Tip
How to test surface burner on Electric range
In order to test the surface burner on your electric range, the following steps should be taken:
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. Remove the surface burner from the stove top. On most electric ranges this can be done by pulling the burner up and out of its plug-in receptacle. Other models have the burner directly wired to the cook top. To remove this type of burner, undo the screw that secures the burner to the cook top, remove the clips that secure the insulators to the burner terminals, and carefully unscrew the wires from the terminals. Take care not to bend these terminals.
  3. Visually inspect the burner - often there will be small holes or bubbles on the surface of a defective element.
  4. Now that you have removed the burner, you can test it using your VOM. Using the ohmmeter function, set the range scale to R x 1 and touch the test leads to the two burner terminals. The VOM should show continuity. Typical burner readings should be somewhere between 19 and 115 ohms, depending on the range manufacturer. If there is no continuity, the burner is defective. To test for a grounded (or shorted) burner, place one test lead on the outside surface of the burner and the other test lead on each burner terminal in turn. If there is continuity at either terminal, the burner is defective.
  5. If the burner is defective, replace with a new one by reversing the removal procedure (step 2 above). If replacing a wired-in burner, make sure that you install the wires on the correct terminals, according to the wiring diagram.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION!!!
on Jan 04, 2011 | Kitchen Ranges
One burner on Kera205pbt won't heat
Just to be clear, the burner does not heat at all? Is this the small or large burner? Swap the burner with another one to see if it is the burner itself or the infinite switch. Post back your results.
Feb 08, 2013 | KitchenAid KERA205P Electric Kitchen Range
Burner light stays on when burner is turned off
Each burner has a sensor in it. These sensors will STICK and stay on even if the burner is off. Usually occurs with the burner that is used the most such as for chicken frying and such. If the burner eye is not the problem then the switch that controls the burner would be the next thing to check. An interesting video that show switch failures:
Jan 11, 2013 | Kitchen Ranges
Tubes blow flames out the front of burner
Burner out of postion , gas leak on control on off . or burner is blocked try cleaning burner some thing could be in the burner causing the gas tO light back , or you need new burner.
Mar 26, 2012 | Nexgrill 720-0234 (LP)
5 burner gas Vicking stove top keeps clicking after is on
Their are 2 possible reasons the igniters would continue to click after the burner is lit.
1) the burner is slightly dirty and the part of it very near the electrode is not burning correctly so the igniter doesn't think the burner is lit so it will not tell the spark to turn off. It could be cleaned by using steel wool and cleaning the burner holes near where the electrode is and then use a paper clip and poke through the holes on the burner to clear them so they burn correctly.
2) the electrode (the spark plug at the burner) is cracked so even though the burner is lit so the electrode can not sense that the burner is lit and wont tell the spark to turn off,so if having cleaned burner it still clicks after burner is lit the electrodes would need to be replaced.
GENE
Oct 08, 2011 | Kitchen Ranges
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
JBP78W electric smoothtop small burner in dual burner not working
you call a repairman, Like I did , expect to pay 150.00 or more as the small burner and large one are in the same ceramic holder
Oct 17, 2017 | GE Spectra JBP78 Electric Kitchen Range
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Problem with double burner Jenn-Air JED8430 Electric Cooktop
It's an ignition switch. don't change the burner cartridge.
May 10, 2008 | Jenn-Air JED8430 Electric Cooktop
Heating & Cooling Logo
44 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
