Question about Kenmore 22422 Top Load Washer
Washer isnt turning on
I bought the thing less than year again and this is the second time i am having trouble but not like this i had a load washing last night everything weent ok i guess and today when i went in to do a load i have no power and the start button is clicking
  • 2 more comments
  • Anonymous Oct 04, 2008
    I have the same issue. This morning I tried to do laundry and the lights don't come on. there is power at the outlet, but..........
  • Anonymous Oct 12, 2008
    went in and the tub was full of water but now there it is like there is no power going to the macjine but the plug works with other things and we've checked the breakers, etc.
  • Anonymous Oct 24, 2008
    My son was trying to run a load of laundry... The water filled up but that's it, no clean cycle, nothing.
    Seems like the switch died but not sure how to check it.
  • john gagnon
    john gagnon May 11, 2010
    is the water entering the washer or is it just dead
  • 261 Answers
Ok lights out and no power. Now according to the model we all have trouble with a series 70 top load washer? If you have no power I would change the timer. If you have time on the console is two side clips that pop off with a flat head screw driver, these are on front left and right edges. This will reveal two philips screws. Once out the top flips back. There should be a diagram for power to trace from the cord. Just for starts measure volts ac where the cord enters the machine. Now this will take logic and patience. Note which wires are on the same side of the power, neutral and hot. With the machine unplugged check continuity according to the chart that shows time and function. This is not too easy as the writing is small, the wires are usually numbered and marked on the insulation. If you find one connection with out continuity when there should be you have found the power issue! You don't need power for this as it is mechanical and contact is contact.
Posted on Nov 01, 2008
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
Washer only works20 seconds then stops
Maybe at 10 years+ of service it is time to stop dumping money into repairs and buy a replacement.
Mar 14, 2017 | Roper Washing Machines
Just bought a front load whirlpool wash machine. when i turn it on it locks door then unlocks door, it does this 2 to 3 times then the washer fills with some water only spins about 3 times then it waits...
This washer will stop and start a number of times during fill as it is sensing how much water it needs. Also you must hook both water line up and have both on. Also you must use HE soap and very little of it.
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hello, I have a frigidaire washer. I loaded it up and started it - the water went in. But after that, it just stopped. I tried it again, tried different cycles, still doesn,t work. The Start light is...
Well I'm not an expert but I have had problems in the past but it was with my top loader washer. Sounds like it could be a number of things: could be the transmission, or could be a switch or an electrical problem (thats the problem with these new digital washers/dryers!). You will definitely have to call a technician unless you can get a manual and try to fix it yourself. Mine is a year old and I purchased some extra insurance for it, like a year or 2 worth when I bought my washer & dryer new. If your washer is less than a year old you can probably get the manufacturer to fix it for free! Good luck!
May 15, 2010 | Frigidaire GLTF1670A Front Load Washer
Top loading Kenmore washer runs for a few seconds then shuts off
It's quite possible, however,
If you're mechanically inclined, I'd check the motor, transmission and pump first.
See the following Whirlpool / Kenmore Service manual for top load, direct drive washers and it's trouble-shooting section.$FILE/L-55.pdf
See the following for how to pull the cabinet, pump, motor and transmission to check them all.
Mar 15, 2010 | Kenmore 43142 Front Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Fridgidaire Washer burning belt!! Help
look on this site for more aid, it may not be your exact model but has advise on burning belts
Nov 10, 2008 | Frigidaire CWS3600AS Top Load Washer
Control locked on ghw920 can u help me unlock
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
The washer isnt draining
fit, make sure the washer is going through the neutral drain before going into spin. Just around 90 seconds of drain right after agitation. If not, it's a gearcase problem covered under warranty for 5 years. Also I have found socks and things caught in the drain hose right where it exits the washer. This will prevent a full drain. back.
Oct 24, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22422 Top Load Washer Logo
Sal De
 Brian Main
Brian Main
