Question about LG Flatron 995FT 19" CRT Monitor
Screen problem The screen works until the first display is up After that its shuts If I change definitions to" enable VGA mode" The display is on low resolution If try to change to higher resolution the screen shuts down ??
    Champion:
  • 277 Answers
Go step by step: 1. maybe you are trying to set a higher resolution then the screen can be 2. its possible that your comp don?t recognize the screen right, check the "display properties" make sure it?s the right model 3. reinstall the drivers. Restart. 4. if its not the software it?s the hardware, try connecting the screen to another computer if it works fine the problem is in the display board . Good luck
Posted on Feb 23, 2006
I have my monitor connected to my laptop because the laptop screen went out. The monitor has been working fine until the last few days but now when I power on the laptop & monitor, the monitor only...
Please restart the computer and go to safe mode by tapping F8 key once the system is restarting choose Enable VGA Mode (Windows XP)
choose Enable low resolution Video (Windows Vsita / 7).
Change the display settings to slightly lesser than what the monitor can handle and shut down and restart the computer in normal mode.
Jan 03, 2011 | Acer X163W 16" wide format TFT Screen 8...
Out of range
Try to change the screen resolution and frequency setting of your graphic card.
1. Restart your PC
2. Before getting into splash screen, press F8 frequently
Choose enable VGA mode by pressing up arrow and press Enter, wait until finish loading. Now the display looks bigger, change the screen resolution to best fit to your Monitor (normally 1360X800). DO NOT CLICK OK>go to advance tab> Monitor tab, choose 60Hz for screen refresh rate, NOW you may KLIK OK
Apr 10, 2010 | LG Flatron L1750S 17" LCD Monitor
On my HP Compaq nc5220 The computer is working and the screen on the monitor is some what 'lit up' but after the initial start up and the Windows HP logo comes across that is it. It will not proceed to...
For that you need to change screen resolution settings in display property.
When you power up the computer press F8 key 5 to 6 times then you can see safe mode and other menu then enter in "enable vga mode" then go to start menu ->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
Then check.
If you are not able to enter in enable vga mode then enter in safe mode and uninstall graphic driver then reinstall driver then it will work.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 08, 2010 | HP Computers & Internet
How do i get safemode in full screen or full resolution so there is not black borders around the out side
When you power up the computer Press and hold F8 key 5 to 6 times untill you see windows logo then you can see safe mode and other menu enter in enable vga mode then go to start menu->control panel->display ->property ->settings .
change screen resolution to 1024*768 then apply and ok.
Then check .
Mar 07, 2010 | Computers & Internet
Black screen comes up on normal mode. only able to run on safe mode.
When you power up the computer press F8 key 5 to 6 times then you can see some menu enter in "Enable vga mode" then go to control panel->display property change screen resolution to 1024*768 then aplly and ok then check.
If same in enable vga mode then enter in safe mode and uninstall graphic driver then reinstall it in normal mode.
Feb 20, 2010 | Toshiba Satellite A215-S7407 Notebook
My fujitsu dont start vga
When you power up the computer press F8 key then enter in enable vga mode then go to start ->control panel ->display ->settings .
Change screen resolution to 1024*768.
Then apply and ok.
But if you are not able to see any display so you need to refix RAM memory if you are able to enter in safe mode or enable vga mode then there is only issue with graphic driver.
Let me know if you need more assistance.
Thanks.
Oct 22, 2009 | Fujitsu Siemens SCENIC P300 PC Desktop
Computer screen blank
u have to need reset bios .
Open cpu cabinet and find mother bord pull cmos cell for 15 minutes from mother bord.
then bios is reset.
Tehn start computer problem still arisde.then when u power up the computer press F8 key then enter in enable vga mode.then go to dispaly property and change screen resolujtion to 1024*768 then apply and ok.
Jun 05, 2009 | E-Machines eMachines Desktop PC
Technically Black Screen
when u power up the system press F8 key untill u get safe mode menu.
then goo to enable vga mode set your resolution to 800*600 or 1024 * 768.
also u can try safe mode or last known good config.
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
Laptop LCD problem
hi, have you tried switching the screen mode, i think its FN button and F4, failing this you may have a faulty LCD controller chip, messy to fix unless you bring it some one who is repetable at fixing laptops...
Feb 19, 2008 | HP Pavilion dv6000z Notebook
SCREEN MESSAGE - MODE NOT SUPPORTED
You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
Sep 26, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
LG Flatron 995FT 19" CRT Monitor Logo
80 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
