Question about Schumacher DSR ProSeries Battery Charger - 250/65/35/5 Amp, Model# PSW-61224
Hi: We purchased a Schumacher SE-4022, (very similar to the DSR ProSeries only 200/100/40/10/2 amp, manual operation). It worked great for the 1st few months & now it has no amp output indicated on any range, and it doesn't charge any of our batteries. The switches / timer / fan, etc seem to work and the unit sounds like it's carrying a load, but no charging output. Unit will probably be covered by warranty, but that take time, and we need it now to charge several batteries. We found a parts distributor, Century Tool, http://www.centurytool.netSE_4022_Schumacher_Battery_Charger_Parts_List_s/30715.htm which offers a rectifier module for $30+, but we can't find a Schematic. Hoping to find a Reset Button, Replaceable Fuse, Etc to have a quick fix, but the parts list doesn't show any of these items. It does now a Breaker, which is supposed to Click Open on an Overload, but we don't hear any Clicks, or see Amps jump, to indicate an overload. Your Suggestion, Troubleshooting Tips, Schematics, Etc would be appreciated & helpful. If your best advice is to use the Warranty, that's OK also...... Thanks, Leo
I'm working on one right now. Not sure if it's the SE-4022 but the ratings are the same. 200/100/40/10/2 Amps. The rectifier diodes exploded in it. ie: Big bang, and smoke. Smoke is never a good thing. Pulled it apart. The diodes are press fit like a lot of car alternators. The number on the diodes is DT B7504A XXXX (Last four digits are a date code. Not important.) The diodes are made by DioTec BUT, they don't sell "retail". They supply manufacturing. I talked to DT's top guy and he told me to get the NTE5934 diodes from Newark Electronics. (Google it if you're not familiar with them.) Present price is $5.24 each. (ie: Cheap.)You have to press the old ones out and press the new ones in. I removed the aluminum plate from the unit and pressed out the old ones with my drill press. Put a deep socket (3/4") under the blown diode sitting on the drill table. Tighten the chuck so the nose is closed and sticking out. Push out diode with the nose of the chuck. Pressing the new ones in is more tricky. Keep the 3/4" socket under the plate. You then want a DEEP socket big enough to just press on the metal around the perimeter of the new diodes. BUT NOT TOUCH the insulator/pin part. You should be able to use the chuck nose against the back of the socket to push the new diodes in. I suggest using some heat sink compound or dielectric grease on the diode before pressing it in. Helps prevent corrosion between the metal plate and diode. THE DIODE HAS TO BE VERY TIGHT IN THE PLATE WHEN PRESSED IN. If it's loose at all, it won't transfer heat to the plate, the diode will overheat, and do pretty much the same as it's predecessor. If the diode(s) are loose after you install them, press them out again, and see if you can "close" the hole up a bit. Suggestion: put the plate on a flat metal surface (back of vise?) with the "flare" of metal facing up. Tap on that flare with a hammer that has a large enough head to hit the whole flare at once. Don't do too much. Try the diode again. Still too lose? Remove and tap again with hammer. Pain in the **** I know, but it's the only way I can see to get the diodes tight. DON'T use epoxy or "glue" in place of tightening the metal. The glue won't transfer the heat. As long as there is nothing else wrong with the charger, this will cost less than $15.00 plus your time. A lot cheaper than buying a new charger.
Posted on Mar 13, 2012
  • 3 Answers
Question, I have a heat sink with 4 holes and only 2 diodes which have to leads on each coming from the transformer, wouldn't be better to replace the 2 diodes with 4 diodes with a single wire to the trans?
Posted on Jul 18, 2015
5 Suggested Answers
SOURCE: battery charger- schumacher se 4020
Century Tool and Equipment. $3.99
http://www.centurytool.net/SE_2158_Schumacher_Battery_Charger_Parts_List_s/30946.htm
Posted on Sep 03, 2009
  • 102 Answers
SOURCE: schumacher ss-51a-pe battery charger with no output.
Soo sorry, unit is DEAD.
Posted on Mar 10, 2009
Thermo King
  • 593 Answers
SOURCE: is the 10 amp se-40ma battery charger to big for
A battery that might sit for a month at a time, would only need a trickle charge or about 1 amp, a charger of this type can stay hooked to the battery for the whole month. A 10 amp would be for a quick charge or only about 4 - 12 hours depends on how fast the battery lost the charge. A 10 amp charge would cook the battery if left for days.
Posted on Mar 26, 2010
  • 122 Answers
SOURCE: lost manual ...how long should i charge my riding
The SE40MAP has an automatic shutoff when battery is fully charged.
Posted on Jun 07, 2011
Do you have a wiring diagram for a Schumacher se-1010-2 battery charger?
What did you find on Google and forum sites are also a great sourse of information.
Sep 16, 2014 | Schumacher SE-1010-2 12-Volt 10-Amp Dual...
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Wiring diagram se-4020 battery charger
try this web site
http://www.manualslib.com/manual/523935/Schumacher-Se-2254.html Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Looking for wirring diagram for schmacher SE-1275A battery charger. Wires got pulled out of component need to know where white wire & black wire goes.
yay I emailed schumacher asking about this and they got bak to me within 12 hours or so with EXACTLY what I needed
I looked a long, long time without finding anything like this online, and many different people asking the same questions
so please save this picture for your records, and if you have a minute, go post it on an unanswered schumacher battery charger wiring diagram question
Jan 18, 2011 | Schumacher DSR ProSeries Battery Charger -...
THE TIMER ON MY MODEL SE-3612 WILL NOT SHUT OFF
go to the intermatic timer site and search for a replacement timer. have you tried the site of the manufacturer?
Oct 13, 2009 | Schumacher DSR ProSeries Battery Charger -...
I have a schumacher se-82-6,i dont use it much and have misplaced the instruction manual.how do i read the guage,when do i know battery is fully chargrd or battery wont charge? thanks erik
If you look at the meter, the charge meter of 100% is slightly above the 2 amp mark so it is confusing. because it says the charge represents the amont charged and the amp meter shows when there is no draw on the charger. so if the battery shows 2.5 amp on the amp meter, it's showing 100% charged. but yet they say it should go to zero on the amp meter, which would mean about 150% charged. i think everyone is scared of blowing up or damaging their batteries because the instructions manual is quite contradictory and confusing. well apparantly, they have several versions of this model to make it more confusing, but here's a pic of what i have.
http://www.northerntool.com/images/product/zoom_images/1677820.jpg
ok, as i was looking for manual online, it is more detailed than the one in box. it now explains this in picture detail. thank you schumacher.
here's the updated manual:
http://www.batterysales.com/downloads/SE-82-6.pdf
hope this helps.
Feb 02, 2009 | Schumacher & Fast Charge Starter Charger
Schumacher DSR ProSeries Battery Charger - 250/65/35/5 Amp, Model# PSW-61224 Logo
2,361 people viewed this question
Top Schumacher Hardware & Accessories Experts
jdthefixer
Are you a Schumacher Hardware and Accessory Expert? Answer questions, earn points and help others
