Question about HP Computers & Internet
COMPUTER RUNS VERY SLOW - HP Computers & Internet
    Brigadier General:
  • 6,966 Answers
Most computers after some time would run slower than when the OS was first installed. This is because in the course of use, several applications installed would be loading up the system. If this is the case (fast before but now slow), pls try:
  • run. scan and clean (with) your antivirus;
  • download, install and run Ad-Aware;
  • clean your temp and temporary internet files;
  • defrag your HD;
  • run "msconfig" and in the Startup tab, un-check everything except perhaps your anti virus;
  • goto Start, All Programs, Startup and remove any start up programs that are not essential;
  • examples of non-essential startup programs are: Google Update/Notifier, Acrobat Reader update, Nero check,
  • tweak/trick your OS;
  • optimize memory usage (must be familiar with registry settings).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 09, 2008
  • 199 Answers
Cn i hav the specs of your pc, and your hard drive free space, and your OS,,
pc's performance and stability depends on your memory, programs that you run, video card and processor,, you might want to check also your free space, try defraging it and disk clean up its a big help
MY COMPUTER RUN SLOW
Usually motherboard either works or doesn't work. It won't make computer runs slow. Your computer runs slow mostly because of low memory, low diskspace available, driver issue, virus, or spyware. If you surf the web a lot, chance is your computer got spyware or malware. Install a free malware program and use it to clean up your laptop first to see if the problem is improving.
Apr 05, 2011 | ASUS Motherboard P5sd2-vm
Runs slow on video downloads
Hello Sir,
downloading speed depends on internet connection not on PC specification.
If your transfer is low then downloading will also be low.
Take note that source from which you are downloading also must have reliable connection.
cheers,
Mike
May 08, 2010 | Gateway 832GM PC Desktop
Runs slow sticks
The link I've give you below is linked to CCleaner which is a registry cleaner for your computer which basically removes un-needed data e.g. Internet History, Internet cache, computer logs and it also fixes shortcuts or any files which are not working correctly.
I use this software on my computer every time I shut down and it has made my computer work much faster.
Here's the link: http://www.piriform.com/ccleaner/download you can download free if you select the 'alternative download'.
Feb 17, 2010 | E-Machines T3958 (827103050974) PC Desktop
BOARD RUNS REAL SLOW
i think it is not true. because speed of computer depend processer and ram . u can chang high config . ram than using . it can help little make high speed. temp file can make slow so time by time we remove this file. virouse can make slow computer. if bord is short it make hang computer.
Nov 04, 2009 | Computers & Internet
When i play rugby 08 in my laptop it runs in slow motion.
maybe it runs slow because you download way to much things are maybe you need to upgrade the version of you computer!!!
Sep 18, 2009 | EA Sports Cricket 2005 for Windows
Slow or not responsive
the performance problem is more likely to do with corrupt system files or a virus and not damaged hardware. Try reinstalling the windows set up disk or partition recovery and let me know if the problem persists.
Aug 19, 2009 | Audio Players & Recorders
Maybe a virus
is it the internet that runs slow or everything? either way, go to the following site:
http://housecall.trendmicro.com/
click on the link that says "Scan Now. Its Free!" it will do an online virus scan of your computer, and this should get rid of any viruses you have. You may have to install Java for it to work. If so, it should provide a link to install it. If it doesnt, google "java software" and download the software. it may also be a RAM problem (not enough computer memory) but thats probably not as likely if your computer is new. Also, you can go the task manager and delete all of the processes that you think arent needed (such as itunes, etc. make sure that your user name is under the user name column for each one you are deleting, and DO NOT delete the "explorer" process or any system processes). And this may speed up your computer as well.
Aug 08, 2008 | Microsoft Windows Vista Ultimate Edition
Runs Slow
Run your antivirus, adware program and scandisk and defrag, in SAFE MODE..
Feb 13, 2008 | Microsoft Windows XP Home Edition
Runs slow
It depends how old your computer is. If your computer is more than 5 years old, there will be a problem since the driver software will not be advanced enough. I reccomend installing new driver software. Look it up. Good Luck.
Sep 13, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
