Question about Sony VPL PX20 Multimedia Projector
A blue hue
The sony projector is displaying a bluish hue on screen. One projector has it on top and another has it on the outsides in a circular manner. color correcting does not fix it. What could be the problem and how to fix it? They are about 5 -6yrs old. Thanks
  • Anonymous Nov 20, 2007
    I have a Sony VPL-HS20 with about 6000 hours and 4 years old.. I have the bluish hue on top. Just noticed it in the last week. Please let me know if you find a solution.
  • Anonymous Oct 21, 2008
    Got a secondhand vpl px20 with a new bulb ...was pretty cool when bought it at first ..but after a 120hrs use it started to get the hue , sepia green/blue-ish ..and it got worse so stopped using it with 150hrs on the indicator counter for the bulb..afraid will be a costly repair ;-(
    Scholar:
  • 130 Answers
If color correcting does not fix the problem you will probably need some professional equipment in order to fix it. It would probably be best to contact a professional service provider.
Posted on Feb 26, 2006
Sony lcd pink color
Check your connections / cables. Sometimes VGA cables will display color hues if not firmly attached.
Nov 10, 2013 | Sony VPLFX52 Vpl-Fx52 Mmproj Lcd-W/...
There is too much blue on the screen & not enough green coloring
Have a very close look at the blue and see if it's perfectly uniform across the whole screen.
If it is then altering the hue or colour temperature settings in the menu may help.
If it's not then either there are heaps of pixel failures (appearing as small rectangular spots) or degradation of the polarisers (green may be affected more than the others).
If you show the menu, do the white areas appear bluish.
If the lamp is very old then colour changes start to happen.
Jun 23, 2011 | Canon Office Equipment & Supplies
XL-2400 lamp replacement.
I have this exact same problem. I even put the old lamp back in to see if it was the new lamp and the same fuzzy orange/redish hue was still there.
Jul 27, 2010 | Sony (XL-2400) Projector Lamp for...
Blue hue on right side screen
Try changing your vga/dvi cable,or it could be colour decay.
May 07, 2010 | Panasonic PT-AE700U Multimedia Projector
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have the Optoma Model EP719 running. When I turn on my computer the projector shows my computer screen as it boots up. As soon as my desktop wallpaper and icons appear on the laptop screen, the...
right click on main screen, then go to properties, then you can adjust resolution, color, contrast, hue, and much more. You can also do this from control panel and under display.
Oct 08, 2009 | Optoma Office Equipment & Supplies
I replaced the XL-2400 complete bulb replacement now I have a pink hue at the top of my screen and green hue at bottom of my tv screen
I change the lamp 4 my tv sony vega XL-2400 and I steel send me a signal to change the lamp what can I do 4 setup.
Oct 05, 2009 | Sony Office Equipment & Supplies
Macbook Pro External 23" Apple Cinema Sceen blue hue
have you altered the white point and temp settings in system prefs / displays
Mar 08, 2009 | Apple DVI-I to ADC Adapter (M8661Z/A)
A blue semi-circular hue on the bottom left of the screen
9 times out of 10 the Blue Polarizer heats up and discolors which causes that problem, all projector's have the same issue and have for years. My professional recommendation is get in touch with Sony, they have been extending the warranty's for this issue. If they won't the have a servicer replace the light engine of which is not cheap.
Jan 19, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Open Questions:
My Ricoh 3035 / Savin 8035 prints uniformly light pages, and tells me to add toner, with a FULL toner bottle. The developer unit itself is completely packed with toner. There are no other errors set. The issue described is recent, within the last 500 copies. Prior to that this machine was running perfectly. I've had this copier for a couple of years. It was used. It NOW has 617,871 prints/copies/faxes as of today. I replaced the developer unit remanufactured and new developer at 591,810. The transfer belt and cleaning blade are new at 607,638. I replaced the PCU with a completely remanufactured unit at 607,688. The fuser was replaced with remanufactured unit also at 607,688. I was STILL having some issues with bad quality copies, so I narrowed the matter down to a defective drum in the remanufactured PCU. I replaced the drum, and at THAT time, I installed every part in the Savin Maintenance Kit PMB082150K, which I previously received with the copier. I also replaced the PCU Entrance Seal and tape the long mylar one at the top of the drum. When I installed the developer unit, I initialized the settings, pursuant to the Service Manual, and the same with the drum, and the appropriate one each time I previously cleaned the ID Sensor Today, I went through the trouble of replacing the ID Sensor, initialized the same, and it made no difference. The copier has run just fine for the last couple of months, and then as I stated in the question, about 500 copies ago, all of the copies suddenly became light. No, it's not the density setting. I've done everything except do a factory reset. Incidentally, I have the Ricoh 3035 Service Manual, and also the Parts Manual. Experientially, the only computers I have ever purchased are 2 of them, for my office, in 10 years. Other than that, I have built every computer I've ever made, from parts. As far as this copier, I have done the copier maintenance, per the maintenance schedule, myself, and when it appears that maintenance needs to be done. This problem however, is driving me nuts. As I said, the only symptoms of the light copies are that add toner light that comes on periodically, and toner absolutely packed into the developer unit entrance such that its spills out when I remove the PCU. One last thing, and this is an when all else fails kind of thing: since the toner bottle is full, I open the front door, and using a channellock, I fix the add toner problem by rapping very lightly on the end of the PCU, and the developer unit! This DOES fix the toner out problem every time, but it does NOT fix the light copies. Simply opening the door, sliding the toner carrier out, putting it back, and then closing the door, and repeating that process a couple of times sometimes also works.
Jan 21, 2019 | Ricoh Aficio 3035 Digital...
See all Sony VPL PX20 Multimedia Projector Questions
Sony VPL PX20 Multimedia Projector Logo
266 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
