Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold refrigerator icemaker leaking water
Please help. My icemaker is leaking inside my refrigerator. At first it was dripping water into the ice box and freezing and we would have to pull it out cut the ice and dump it out every week. Now it has progressed to leaking out of the ice despenser. Thank you for your time. Do you have a clue as to what I can do to fix this?
  • 2 more comments
  • mlearly001 Sep 13, 2008
    Mine started leaking out of the ice dispenser and now occassionally leaks out of the edge of the water/ice dispenser unit (seam). Seems like the flap to the ice dispenser might be broken (not sealing) and letting air in to create ice buildup.
  • Donna Fulton-Teters
    Donna Fulton-Teters Sep 16, 2008
    Thank you. My model number is gd25dfxfw02.
    Thank you soo much for your help.
    Donna
  • blessedby3bo Mar 15, 2009
    I have the same problem. my whirlpool gold refrig is leaking out the ice despenser on the door and is building up inside the freezer. Looks like snow, since its not hard ice its hard to pinpoint where the leak might be. Sounds like a defect. perhaps there is 'recall' for th is problem. Any news or ideas
  • Anonymous Mar 31, 2014
    water drips into refrigerator and freezes
    Sergeant:
  • 409 Answers
sounds like the ice or water actuator or paddle is broken. purchase a new paddle and replace it.
the reason you have leak is because you have warm air entering through the broken part into the freezer.
can you provide me with the model # and i will send you a part breakdown.
Posted on Sep 16, 2008
  • Carmen Mikulic Sep 16, 2008
    hi there,
    please visit www.whirlpoolparts.ca
    this website will give you a parts breakdown for your model fridge
    Dear mlearly001
    i would recommend a technician taking a look, as it requires tools and some disassembly.
Thanks, Squishy2! I have a Whirlpool Gold Conquest. I'll check the model number when I get home tonight. Do you think this is a job for a non-professional?
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: whirlpool gold refrigerator icemaker leaking water
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
My "Whirlpool Gold" Refrigerator's interior water dispenser was dripping pretty badly. I just replaced the inlet valve and the drip is MUCH slower but it's still there (1 drip every ~10 minutes). Wha
Perhaps some air bubbles were trapped in the water line during the repair. Try running water thru the line for a good amount of time and that may help to relieve the line of any air bubbles.
Jan 26, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
I have a whirlpool imperial refrigerator; freezer on top; with icemaker....water is leaking from the freezer section down onto top shelf in refrigerator, near back, any help??
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. This is all you need to do....
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Whirlpool Refrigerators
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Apr 04, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold GS6NBEXRB01 - While Auto-Defrosting, the water drips into freezer from inside Grill
you have a frozen or blocked defrost drain behind the back panel with the vents in it remove the panel and clear the drain at the bottom in the silver pan
Jun 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
2,727 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
