posted by shots on Feb 23, 2006
When insterting a dvd-r disc in the unit it reads and says to reject the disc because playback feature may not be availible.
I want to dubb vcr to dvd but it will not accept the commands. THis is a new machine.
Best Solution
posted on May 04, 2007
I am having the same problem with mine too - ewr20v5. I just talked to a customer service rep, and he said that to take a disc cleaner to it, and then if that does not work call for a firmware upgrade. That should take care of it. I asked if this is a recurring problem and he wa shemming and hawing about it and finally said "sort of". So in my opinion I think the Emerson folks know there is a problem and are hoping that everone just lets it go by the wayside. I will try to clean it this weekend and see if it works. If it doesn't then I will get the update and try that. If that doen's worj I anm probably going to just give it to Sal's Army or Goodwill, or just junk it. At that point, it is not worth the trouble - will probably just get a new one since they are so cheap now.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 23, 2006
hi
try antoher disc and c if it does it again
if so...take to fix or change it
if its new it still have warranty!!
good luck
good luck
Solution #3
posted on Apr 19, 2008
This unit here can only use DVD-R (2x or 4x) or DVD-RW (1x or 2x). Anything other than that will result in a disc error.
Also, check the error message it is giving you when you press record. It will be an E followed by some numbers. If it is an E4 and more numbers, then the unit needs to be serviced. You can try running a disc cleaner but if that does not work, then haveing the unit serviced is your best bet.
Suggest a new solution for this problem
Post a New problem for Emerson EWR20V4 DVD Recorder / VCR
Email this problem
Email this problem
Can you Help with these DVD Players problems?
Emerson EWR20V4 DVD Recorder / VCR Combo
Emerson Model EWR10D4
I have a DVD player/recorder... Answer This...
VHS - audio...
VHS - audio...
Wanted to watch a vhs tape,... Answer This...
DVD VHS player not working
Hi this morning I turned on my... Answer This...
can't read blank DVD for...
Hi. this is my first time to... Answer This...
How to record or dubbing from...
I caanot proceed to dubbing... Answer This...
Repair Service
Find DVD Player Repairman Near You:
