Question about CTX Professional PureFlat PR960FL 19 in.CRT Conventional Monitor
Colour adjustment Is there an engineering menu to adjust the RGB black levels (cut-offs) as my monitor is looking blue in the dark areas?
  • UberHank Apr 28, 2008
    I have the same problem! My monitor is awfully blue where it should be black. It is a pain for normal use and especially the gaming I enjoy. Thanks for any help!
    Champion:
  • 277 Answers
Hi try lighten up the whole screen - its the "sun" icon and raise the contrast - its the half black hlaf white circle icon if it dont work , give us more details hope i helped
Posted on Feb 23, 2006
SOURCE:
Tip
How to save power even you are still using old VGA Monitor
Older monitors(CRT type) are using complex circuit than LCD, It requires more power consumption than LCD, but you can still save power by 30% through this tip.
1.You must position or install your monitor in a dark area or position.
2.Adjust the brightness control to the level of the black part of the picture must be seen black not gray, or became white.
3. Adjust the contrast control at your most comfortable level.
4.Avoid using bright picture screen saver or blank screen saver.
5.Turn off your monitor manually if necessary.
on Jan 19, 2010 | Computers & Internet
RGB Colour problem
We re sorry
Try the manual.
no idea what 100 refers to.
Apr 04, 2014 | Dell E772p Monitor
Lock on monitor adjustments don't know how to turn off the lock so we can adjust brightness and color
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
Dec 24, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Its glittery white because i briten the color but when darken it gets green
you must re-adjust in the RGB (Red-Green-Blue) setting. depending on the brand of your TV, because there are set manually from the TV (you must open the cover of the rear of the TV). and there is a set directly from the remote only, with the open "factory settings", then you can re-adjust RGB color, especially green, not too dominant with the other colors (RED-BLUE). how to set is that you need to neutralize the color, (color TV sets to zero level) so that the image becomes black and white. if the green is too dominant, then Decrease the level of Green Bias or Green Cut off/ G-drive.
Aug 05, 2010 | Televison & Video
50V715 HITACHI -GREENISH TINT -
Solution for the Hitachi 50V715. I contacted Hitachi and they told me there is a problem with the color engine with this and other Hitachi models. They will replace the part for free, but first I need to take it to a repair shop to verify the problem and I have to pay labor. Not too bad considering the cost of the engine.
Dec 19, 2008 | Hitachi 60V715 60" Rear Projection...
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Samsung monitor and mac os
Please do not adjust RGB unless you know what you are doing.
For critical color work, you will need to use a photospectrometer and calibration software to analyze what your monitor is spitting out.
There are a million obvious reasons you should not trust your eye making arbitrary RGB adjustments off the hip.
Feb 15, 2008 | ViewSonic VX2255 Monitor
Monitor problem
Replace video filter capacitor supplying voltage to RGB driver transistors like 47uf 160v.
Aug 05, 2007 | HP Compaq FS7600 17" CRT Monitor
Color Problem:
in Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
Jan 09, 2007 | Samsung SyncMaster 551 15" CRT Monitor
CTX Professional PureFlat PR960FL 19 in.CRT Conventional Monitor Logo
Top CTX Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Steve Allison
Steve Allison
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
