Question about Philips 46PP9302 46" Rear Projection Television
Philips 60pp9363h/17 I have the same problem with the picture warping and the colors out of whack. Philips 60pp9363h/17 Where do I get the convergence ic's and where are they located in the unit?
  • crobson Sep 10, 2008
    I have the same problem too... was anyone able to fix theirs? What was the cost?
    Thanks
  • Philips Master
  • 3,459 Answers
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Ed
Posted on Nov 28, 2008
My philips 60pp9363h/17 is really dark and has a really red tint to it....we have tried adjusting the color of the t.v. with the remote but it dosent help.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 16, 2011 | Philips 60PP9363 60" Rear Projection...
60pp9363h/17 tv has got convergence issues and a tech shop has it now but says they can't fix it, parts aren't available and what parts they have tried havn't worked so far?????
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 02, 2009 | Philips 60PP9363 60" Rear Projection...
SOUND BUT NO PICTURE
is it nothing on the screen at all? if so your projector bulb blew. they usually cost a coupole hundred bucks
Mar 07, 2009 | Philips 60PP9363 60" Rear Projection...
Phillips 60PP9363H/17 Picure warped and collor drifting
You have a convergence chip problem. You need to get a kit from www.TvRepairKits.com.
Note: The longer you run your set with a convergence problem the more problems you will have. Turn it off and get it fixed.
Nov 14, 2008 | Philips 60PP9363 60" Rear Projection...
Phillips hd projection tv/ model 60pp9363h/17
thats a common problem with all projection tvs. You will need to replace both convergence Ics and 4 resistors. You will need two STK392-120 Convergence ICs and four 6.8 ohm 1watt resistors. You can get replacement parts at the following link and they provide free instalation instructions so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Philips 46PP9302 46" Rear Projection...
Picture is warping and colors are seperating giving a picture that looks like a 3D picture without the glasses
you need to replace both convergence Ics. Post the model number of your set and I will post the correct IC numbers as well as alink where you can get replacements with free instalation instructions. Respond to this same post so I will have access to your symptoms when you post the nodel number.
Jun 30, 2008 | Philips 46PP9302 46" Rear Projection...
Philips 60PP9363H/17
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 11, 2008 | Philips 60PP9363 60" Rear Projection...
Do you want a convergence board? I think it is the SSA module. You can get a new one from partstore.com or I have a used module from a scrap unit.
Dec 29, 2007 | Philips Magnavox 51MP392H Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
586 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
