Question about Dell UltraScan P1110 21" CRT Monitor
Ultrascan P1110 to Bright....
I have a P1110...and I have the brightness turned all the way down, and the contrast all the way up, (only way the screen looks close to correct). Black looks grey...and I can adjust it any further down... is there a Main adjustment inside to turn the brightness down any further? Other that the brightness, It works great... Can Someone help me?? Thanks
Repair enginear india
Posted on Jun 15, 2008
Step by step fix
http://fyrskeppsvagen.com/tips/dell_monitor_p1110/index.html
Posted on May 17, 2008
This is a known issue in all trinitron monitors. The most popular and successful fix is to do a hardware hack. i am sure by this time you would've found that hack by googling! :)
Posted on Nov 25, 2007
    Champion:
  • 277 Answers
Hi sounds like you have weak picture tubes do not open the screen ***DANGER OF ELECTROCUTION AND DEATH*** try taking to some1 who knows how 2 fix it good luck
Posted on Feb 23, 2006
Hitachi CP-X1250 MULTIMEDIA PROJECTOR - MENU> MAIN> BRIGHT and CONTRAST are not active. BRIGHT and CONTRAST How to enable? I can not make adjustment.
hi,
Go to menu and then select main. then select reset and execute it.After that try to adjust the brightness and contrast.
Remember on thing, in some projectors the brightens and contrast will be active when there is video signal. also try that.
ok
Jan 26, 2011 | Hitachi CP-X1250 Multimedia Projector
Screen is gone really bright and turning down contrast or brightness doesn't fix problem. Insignia LCD 26 inch
try turning down the backlight option in your menu. You should be able to find that option under picture settings.
Aug 07, 2009 | Insignia LCDTV26 26 in. Television
My contrast and my brightness is very dark on my laptop and i can't see anything. How do i make it bright again?
Most laptops adjust brightness and contrast using the function key. Pressing and holding the function key ("Fn") and press the up or down arrow keys to increase and decrease the brightness. You can determine the keys brightness or contrast by looking for keys on the keyboard that have pictures of a sun or a half moon.
Jul 18, 2009 | Microsoft Windows® XP Professional Full...
When i turn on my computer, it displays signal cable disconnect,and the restart switch doesnt function
try 2 check the cable if it is properly attached. try connect a different cable from your computer to your VGA
Jan 25, 2009 | Dell UltraScan P1110 21" CRT Monitor
Toshiba Sat A75-SP231, Display too bright no contrast
There is a brightness setting on your keyboard on ours it is Fn F6 to turn down the brightness. Just look for a sille "sun" symbol with a downward triangle symbalizing down. Try this and get back to me if it does not fix the problem we can try something else
Jan 13, 2009 | Computers & Internet
Too Bright
It could.Check the screen voltage G2,If its high more then 400v this fix could work.
Samir
Mar 09, 2008 | Dell P1130 21" CRT Monitor
Squares visible in bright colors
Turn down the contrast to about 55-65% of maximum. Also turn down sharpness to about 10-20% of maximum.
If ther is a Contrast Plus option, or digital contrast, turn to minimum or off. (Dependant on TV)
This is a common side effect with digital television.
Jan 23, 2008 | Philips Magnavox 42MF521D/37 Television
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Ccreen quality
There is no yellow tube my freind, only a red, blue, and a green one. If its too bright, have you tried to turn down the black level yet or brightmess, and also the contrast. On these sets you don't need to have the brightness up way high, as the contrast does this. If, when you turn down the brightness, and the picture looks dull, you may need to clean off the mirrors, and or the lens for the picture tubes. If that does not help, there could be a problem in the screen drive circuit or the high voltage block. Good Luck Ps Please do not forget to rate this thread.
Dec 08, 2006 | RCA P52926 52" Rear Projection Television
Dell UltraScan P1110 21" CRT Monitor Logo
326 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
