Question about RCA P52771AT 52" Rear Projection Television
Blue shadow RCA p52771at
We have had all 3 guns replaced and now have a blue shadow problem. The shadow appears most often when a very light subject is next to a very dark background or vice versa. After guns replaced the entire picture was very dim and the repair person took it back and realigned it. The brightness is better, but now we have the blue shadow problem. The repair person now says it is possibly a problem with the tuner. Does that sound right? Any recommendations for a repair person in the Houston area?
    Champion:
  • 277 Answers
Hi yeh it does sound right sorry do know anybody arround there... good luck
Posted on Feb 23, 2006
Rca rear projection screen way to much blue
replace convergence ics .press the menu and go into the convergence
alignment.see if you are able to align the blue convergence. if not replace the convergence ics.
Aug 04, 2009 | RCA P52771AT 52" Rear Projection...
Lightning Problem
I HAVE A 61" RCA INFOCUS ALL THE LIGHTS IN FRONT OF THE TV IS BLUE YOU UN PLUG IT AND PLUG IT BACK IN IT STAYS BLUE. YOU CANT TURN IT OFFOR ON
Apr 14, 2008 | RCA HD61THW263 61" Rear Projection HDTV
Blue Halo and too much blue...
if its a halo such as a glo you need coolant change in the CRT, if its like a 3D effect then you need new Convergence ICs. Can you post a picyure of your screen and I will properly diagnose it for you then be better equiped to help you properly.
Apr 04, 2008 | RCA P52771AT 52" Rear Projection...
Rca p52771at
Sounds like you have a bad screen asy,check around the pots to see if cracks are present,part number for this item is 204809,must use the generic,the part is no longer available from Thomson.
Feb 05, 2008 | RCA P52771AT 52" Rear Projection...
Red and green do not light up
Start by raising the screen control for the red and green to see if they have any type of luminance.
C-Dog
RED LINES
Your red CRT socket may be loose or have cracked solder if not, try turning down the red gun screen control inside the set just a little. Youre experienceing what is known as retrace lines
Jan 21, 2008 | RCA P52771AT 52" Rear Projection...
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Wire diagram for splitter
On the 205064 hv splitter with the splitter mounted in the set,left to right, hv transformer,red tube,green tube,blue tube,plug on right side goes to screen asy,the black wires plug on the left side of splitter,which are grounds.
Jul 28, 2007 | RCA P52771AT 52" Rear Projection...
Rca tv p52771at problems
Mine did the same thing it ended up being the splitter. About 200 bucks. And then a year later it did it again. Another 200 bucks.
Nov 04, 2006 | RCA P52771AT 52" Rear Projection...
Rca p52771at - dark picture
Sounds like a bad screen asy,part number 204809,must use the generic,or you could have weak tubes,if so you may just need to turn up the screen drives,this part is located in the right top of the set with the back removed,if no cracks are present adj. the three marked screen's,turn the color all the way down in your menu and adj. for a black and white picture.
Oct 07, 2006 | RCA P52771AT 52" Rear Projection...
Televison & Video Logo
112 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
