The mouse isnt working and actually have discovered that both the usb inputs at the back are inactive.Don't know how it happened or how I can fix
    Scholar:
  • 27 Answers
I just wanna ask, have you tried the other ports of your desktop or laptop? If you did and its still not working, an issue of installation of drivers for your MOBO. Its seems to me, your USB Controller doesn't able to recognize your Type A USB port because the driver wasn't installed on your motherboard that needed by the O.S.
To check if the driver is installed, using your keyboard, press WinKey+Pause/break and the System Properties appear. Then click the Hardware Tab and click the Device Manager Button. Under the Device Manager, if you see any mark of question marks (colored yellow), this only means you still need to install some drivers needed by your MOBO.
One thing else, just to be sure, SP2 ( Service Pack ) also resolves major issues when it comes to USB problems. So you should be installing this on your system also.
Posted on Sep 09, 2008
Problem with mouse usb
It sounds to me like your USB mouse is not USB2 compatible. Use it while it is connected to the USB3 port. Did it at one time work in the USB2 port?
Mar 19, 2014 | Computers & Internet
My M-R0013 or M215 logitech mouse isnt working the light at the top witch useually is green is now red and the mouse isnt working i tryed new batteries but it didnt work still i think it might be USB
Try out MS Fixit. Use IE (Chrome did not filter correctly). SelectWindows. Use USB as the filter.
There should be 2 executables (test these) and maybe some other solution. This a fairly new and dynamic site, so a little feed back would be great.
http://support.microsoft.com/fixit/
Oct 09, 2012 | Logitech WIRELESS MOUSE M215
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
My mouse don't work and my usb input don't work either
go to device manager,Universal Serial Bus controllers and see if there's a device with "?" sign on it,if there are,uninstall the device and restart your computer
Aug 25, 2012 | Toshiba Satellite P15-S420 Notebook
USB mouse not working?
Ok don't worry. Sounds like you need to Unplug the mouse for a sec then re-plug it back in to reset it. If the mouse is wireless then try replacing the batteries. Cause a wireless mouse can still turn on if batteries are weak but won't have enough power to connect to the receiver connect to the desktop/laptop. Try doing so and let me know if this solves your issue.
Aug 24, 2012 | Computers & Internet
Usb mouse stops working vary often, almost every 10 minutes..to fix it I have to disconnect it and put it right back but that's temporary.
It sounds like you have a faulty usb connection inside your laptop, Try putting mouse into another usb jack onto your laptop, or try connecting something else ie camera, phone to the usb you have been using for your mouse. If all is well when connecting another device to same usb, It maybe a fault with the mouse itself and not your laptops usb. Let me know if you connect another device if problem happens the same or if it works. If it works it's a fault with your mouse. Maybe a break in the mouse wire.
Hope this helps, If you need anymore info please just ask away and I'll be happy to try and help and resolve this issue for you.
Mar 06, 2011 | Computers & Internet
Good day, my LG S50 laptop does not read any device. I had it prevoiusly fixed when the same problem occured, unfortunately I cannot get hold of the guy that fixed it. he loaded a CD and installed...
The first step is to completely shut down and re-start the laptop. That alone may fix it.
If that does not solve the problem, unplug the USB devices and bring up your OS Device manager.
Inside the device manager, right-click on the mouse and other USB devices in question and uninstall the devices.
Restart you laptop. After it has come up and stabilized, plug the mouse in and let the system re-discover the mouse. If that works, plug in the flash drive. It should then re-discover that too.
Oct 24, 2017 | Computers & Internet
Hi I have a KM80545 (mikomi) Argos value range wireless keyboard. The keyboard has been working fine until the batteries needed changing. Hence I have changed batteries and the keyboard doesn't seem to be...
I had the exact same problem but with my mouse! the keyboard worked so it obviously was a problem related to connecting to the router (USB)
I later discovered that the LED light on the USB is a button, so click that and click the little circular button on the back of your mouse, then be patient, the mouse should reconnect!
Apr 24, 2010 | KME PC Keyboard and Mouse
I have a GE wireless optical mouse that has decided no to work
I had the same problem till I discovered there are two buttons (not just one) you have to push to re-link the mouse and the USB receiver. Plug the little receiver in, push the tiny "connect" circle on the receiver (which is actually a button I guess), then wait for the red light to start blinking. Then press the little link button on the bottom of the mouse.
Jan 18, 2010 | GE Wireless Optical Mini Mouse 3087897985
My wireless mice's usb doesn't work?
Your wireless mouse must have come in two pieces, the USB connector the mouse itself.
Insert the USB connector of your wireless mouse to your laptop and press simultaneously the button in your USB connector and the button in the wireless mouse. This is done in order to pair the mouse to the USB connector.
Jan 05, 2009 | Targus AMW05US Mouse
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
