Question about ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Does not boot from SATA drive.
SATA drive; PCI SATA controller. Selected SCSI in BIOS boot menu. Result--"Please mount system."
  • 488 Answers
Hi Grumpy
It sounds like your mainboard is not set up to allow for a SATA boot drive.
Have a look in your bios and ensure the boot order is set to the SATA drive first
Then, make sure the SATA drive is formatted and has an operating system installed.
Alternatively, boot the system from a boot disk ( your XP or Vista disk will allow this) and check to see if the board can see the drive and can read the drive if it is already formatted.
If not, format it and install the O/S onto it and make sure you answer YES to the question " do you wish to boot from this drive?"
Both my systems use SATA drives and I only had a boot fault because the "pre-formatted drive" I bought was not formatted and formatting under windows during O/S installation solved this issue..
Swoop...
Posted on Oct 28, 2008
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
I have a compaq evo w8000 desktop and want to install a sata drive instead of the built in scsi drive. I can install windows xp (i've got the sata card drivers and pressed F6 etc, that all works fine)...
ok a very very old DT , desk top, ive done this vast times, back long long ago... 17 years old, you use this old of hardware why?
we dont use XP in uSA its VIRUS magnet. horred
and no updates, now, means will get worse each day forward in time. endless...
has built in, SCSI chip. l Ultra160 SCSI and Ultra ATA/100
that ATA means PATA port, not SATA back then.
my wild guess now is that someone put an a new SATA card in the PCI slot, (ive done so vast times)
The BIOS in your machine will never support that.
that means you can not boot to PCI SATA. for sure.b
but wait, the better SATA card works just like a new Adaptec
ultra160 card that if love.
the new SATA card has what is called a BIOS extension ROM on said card, and a new HOT key to access it.
some are CONTROL +A but each maker of said card ,does as he pleases, so READ THERE MANUAL.
you set it to boot o STAT port and it does if port 0 is bootable drive. SATA.
here ill take you now to newegg.com and show you hardware that works.
if you showed a photo of your CARD and # id have answered, 10x better. !!!!!
i cant shop for you, nor pick SATA 1 ,2 or 3 for you.
but here
https://www.newegg.com/Product/Product.aspx?Item=9SIAC0F5KW5808&cm_re=sata_card-_-9SIAC0F5KW5808-_-Product
the big trick here is making sure you relic MOBO
supports the current levels of PCI>
like above
32-bit / 66MHz PCI interface compliant to PCI Rev 2.3
(Backward-compatible with PCI 33
https://www.promise.com/media_bank/Download%20Bank/Datasheet/FT_TX2300_DS091406.pdf
Control +F (see page 11)
https://www.promise.com/media_bank/Download%20Bank/Manual/FastTrak_TX_Series_User_v3.2.pdf
warning, ive run in to big problems using very old relic
motor-boards that use the very old PCI signals and levels.
and will fail on some newers card
I warned you,
the above reads good. for that. (hope )
now my question why use such old hardware.
when goodwill has truck loads of 10year old pCs for $20
why, love of XEON?
id trash it.
find a use desktop with SATA ports, ALL DO now, or scrapped.
May 08, 2017 | Compaq Evo Workstation W8000 PC Desktop
My IBM System x 3200 M2 server tries to boot from USB Hard Drives that I have installed for backup purposes. I have tried the config/setup utility (pressing F1 at startup) but cannot find any options to...
To change the startup sequence for PCI devices, start the
Configuration/Setup Utility program, select Start Options from the main
menu, select Startup Sequence; then, select Second device (SCSI) to
AGP slot
PCI slot 1
PCI slot 2
PCI slot 3
PCI slot 4
PCI slot 5
Please rate if Helpful
Thanks
Apr 14, 2010 | IBM SYSTEM X3200 M2 E4600 2.4G 2GB 2MB...
With a IBM 6223 can I mix sata and scsi drives in the same machine?
Yes. you can use any mixture of different interfaces a PC. As long as you have the appropriate controller interface to plug the drive into, and your power supply is big enough to support the drive(s) you're using, there should not be a problem.
The only caveat is that if you want to boot from a drive type that is not part of the PC bios, this may not work.
Such as if the bios is so old that it only has IDE and you plug in a SATA or SCSI adapter, it may take some fiddling to make it boot properly. Many interface adapters have their own bios, and sometimes things are not as compatible as they should be.
Oct 21, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Jul 17, 2009 | IBM eServer xSeries 206
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
ASUS P5S800-VM Motherboard set up
Hi m_k_bishop,
You must connect the CD-RW drive to the Secondary IDE connector on your board.
It can not be connected to the Primary IDE port.
(All SATA drives are seen as master drives in the bios).
With that in mind there shouldn't be any data cable connected to the Primary IDE slot.
When you first load the Bios menu screen you should see your CD-RW listed & you should see your SATA drive listed. Go to the title, " BOOT " in your bios.
(If your system has a floppy disk drive connected your Boot menu should read as follows);
First boot device [Floppy Disk]
Second boot device [Your CD-RW drive]
Third boot device [Your SATA drive as shown from the main menu]
No need for a fourth device.
Save the bios & exit. The system will auto restart.
(At boot up re-enter your bios).
Next change the [RAID Mode] to SATA or Enabled anything but RAID.
Once completed save & exit the bios. If everything is connected correctly & you made the changes above your system should see your SATA drive & windows should install.
(Load the windows CD into your CD-RW drive).
The Asus manual lacks the proper information needed for you to make the correct setting changes in the bios.
Good luck m_k_bishop!
Post back if still have trouble... You shouldn't!
Mike
Mar 21, 2009 | ASUS P5S800-VM Motherboard
Tyan S3992 MOBO with scsi drives and tape drive
Only if your BIOS supports booting off the particular device. You could also try to swtich the two PCI slots. Put the tape drive controller in the 1st slot,and the SCSI controller in the 2nd slot.
Which tape drive is it? Is there a firmware update for the BIOS for that PCI controller? I would perhaps contact the vendor of the tape drive/controller
Feb 23, 2008 | Computers & Internet
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard Logo
1,013 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
