Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Water Line Problem
My frig has been in storage for 2 years but last time it was used it worked.  Today, the complex I moved into finally fixed my icemaker water line (the brass line had a crack in it) and connected it to my GE Profile.  I just got home and found the line fixed, but when I turned on the small spigot under the slnk for the line, it all came leaking out from right under where the brass line connects to the refrigerator.
I was looking for someone that could service the unit in my area but came across FixYa so I thought I would give it a shot.
Thanks all!
RIchard Garneau
    Brigadier General:
  • 6,966 Answers
It would appear that the leak is from the junction/joint/connection. This could be caused by:
  • missing, damaged or incorrectly installed seal (O-ring);
  • too much clearance (could be corrected with the use of a teflon tape);
  • loose thread, damaged fitting.
Should be relatively be an easy fix with the right tools and supplies. Worst case scenario would be stripped thread or crack lock/casing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 09, 2008
    Master:
  • 763 Answers
Sir may i know when did you bought your frig? or try this link to help you
http://www.acmehowto.com/howto/appliance/refrigerator/diagrefrigerator.php
or this one too
http://www.refrigerators.com/refrigeratortroubleshooting.aspx
ill find some solutions for your problem.
CHARCOIS
  • GE Master
  • 19,396 Answers
Well iof it has been repaired, and crack fixed, then repair has not been done properly, if it has been replaced check joint, and check that is not another line leaking.
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
I have just moved in to a flat with a vent axia storage heater. I switched it on last night and although the output in off it is still heating up the room today. Is that normal? thanks Heather
Yes, Heather, it's working correctly. It lives up to it's name "storage heater". When you turned it on last night, it heated and at the same time it was storing heat to be used later, during peak electrical use hours, without having to use any electricity. It's working as it should.
Hope this helped you and thanks for choosing FixYa.
Jul 28, 2011 | Heating & Cooling
My water dispenser quit working on my GE GSH25JFTAW side by side frig (I believe 4 years old). When I defrosted the freezer (because the fan was making a howling noise) and re-assemble it, the water...
Ken
Most likely the water line inside the freezer door is frozen( very common problem.. No long term fix out there other than defrosting the line(you did that when you defrosted the whole fridge) the trick is to run the water a lot the first day or so..sensors and motherboard have nothing to do with that..
Jul 07, 2017 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
GE side by side refrigerator water dispenser slow starts.
Well, the age doesnt help it, but have you ever changed the filter and had it all cleaned, if not all must be cleaned and filter changed, that should do it
Feb 09, 2010 | GE GSH25JFR Side by Side Refrigerator
I have a 1993 geo tracker 2wd and today took it for emissions test and it failed for excessive NOx. The tech who tested it informed me that it would either be timing, temp, egr valve or cat conv. Last year...
The check engine lights come on every 50k miles on the Trackers as maintenance reminders so you can take to a dealer to pay big bucks for him to push a slide switch hidden underneath the left speaker cover! Sounds like you have a bad chip in your ECU unit causing the injectors to give the engine too much fuel. You can replace just the chip, but the catalytic convertor can be partially stopped up if it has been running too rich for a while, the oxygen sensor would be what I recommend you replace first.
Oct 06, 2009 | 1993 Geo Tracker
My 1-year old whirlpool fridge ice maker has stopped working
from the back of the frig follow the water line to where hooks to the house water line once you find it turn it off all the way and tightly then open it all the way up.......because if its located on the bottom of the pipe sometimes it plugs up and you'll clear it this way
Sep 06, 2009 | Refrigerators
Low water pressure on door dispenser
i have a similar problem. my water dispenser worked perfectly with the origional filter for about 8 month . then there was a decrease in water output. i then changed the filter.this worked fine for about 2 weeks . changed the filter again 2 days of water output. i have since changed the filter 2 more time with the same results. i do not have a kinked line . i have had the refer for about 1 1/2 years. ice production is down also . any thoughts?
Jul 01, 2009 | LG LFX25960ST Stainless Steel French Door...
Filter pump will not work
take a pliers and turn shaft with pump off if it turns, turn pump on they tend to stick from not being used
Jun 08, 2009 | Intex Krystal Clear Model 635 Pool Filter...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
82 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
