Question about Kenmore 46462 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer. The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
  • 91 Answers
Unless you have alot of money to throw away ,, will run you about 600 to repair washer ,,,not a really good investment ,,
Posted on Jan 04, 2009
How do you remove the front kick panel
Here are the steps.Hope this helps.
Insert a putty knife between the top of the kick plate and bottom of the front panel near the center of the washer, if you have an older model top load washer. Move the putty knife blade in and out in that area until you feel an obstruction. The obstruction is the kick plate retaining clip
Press the putty knife blade over the spring clip until you feel the clip disengage. Let go of the putty knife and grab both ends of the kick plate with your hands. Pull the kick plate away from the washer
ift the front of the washer with help from a friend, if you have a front load model Whirlpool. Slide a block of wood under the front of each side and gently lower the washer Remove the three hex head screws on the bottom edge of the washer kick plate with a Phillips-head screwdriver or nut driver. Pull the kick plate away from the washer.
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
LG front load washer A coin fell in between drum and housing.coin rubs on drum while spinning. how do you access the area between the drum and housing?
take off the front panel
on the bottom/front of the drum is the heater- held in with 10 mm nut - slacken the nut- this will loosen the heater in its holder- pull out the heater- this gives you access to the bottom of the tank
Jul 16, 2009 | LG WM-2277HW Front Load Washer
HE4t kenmore washer rubber drum gasket not attatched.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
Jan 17, 2009 | Kenmore Elite 45986 Front Load Washer
KENMORE FRONT LOAD WASHER - PULL THE SHAFT OUT OF THE BEARINGS.
NO , if there is damage to the shaft you will need a drum BIG $$$$$$$$
Jan 17, 2009 | Kenmore 43052 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Jul 28, 2008 | Kenmore 46462 Front Load Washer
Stainless steel drum loose
A loose inner drum usually indicates a failed rear tub bearing. The only solution is to replace the rear half of the tub. (which contains the bearing).... You can check if the pulley nut has come loose by removing the rear panel. There is a large nut that retains the belt pulley to the shaft of the basket.
Jun 04, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 22992 top load washer
Remove the front panel and youll see.
May 20, 2008 | Kenmore 22422 Top Load Washer
Kenmore 46462 Front Load Washer Logo
502 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
