Have a HP DV9500 laptop and I am trying to remove Windows Vista and install windows xp. When I get to the blue screen to start the install it says it can not locate my hard drive and the only option available is to quit the install. Is there some kind of protection on the hard drive?
    Novelist:
  • 130 Answers
Hi.
I will explain you the issue.
The notebook is preinstalled with a SATA hard drive which needs seperate drivers to be installed inorder to get the hard drive detected. The drivers for the SATA can be installed only by using a floppy drive. As the notebook does not have a floppy drive installed, we can either try disabling the SATA native support in BIOS or install the drivers with the help of a USB floppy drive.
If the USB floppy drive is not available, you have the alternative steps to install the SATA driver.
Please refer the following link to install SATA driver without the USB floppy drive:
http://www.scribd.com/doc/4864999/sata
or
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/sata.pdf
If you have the Floppy drive you can install the SATA driver.
Just follow the below procedure:
Download the SATA driver:
ftp://ftp.hp.com/pub/softpaq/sp37001-37500/sp37005.exe
1. Download the driver to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions. A diskette containing the driver is created, and the driver files are also made available at c:\swsetup\sp37005. If you choose to cancel diskette creation, you will need to copy the driver files to the chosen media.
Installation Instructions:
NOTE: A USB diskette (floppy) drive is required to use this driver. If an external USB diskette drive is used, ensure that it is plugged into the system before starting Step 1.
1. Insert the operating system CD, and Power On the notebook to boot
from the CD.
2. At the very beginning of the operating system installation, the following prompt is displayed at the bottom of the screen:
"Press F6 if you need to install a SCSI or RAID driver...."
When the prompt is displayed, press F6.
3. Later in the operating system installation, you are notified that a mass storage device could not be detected. When this notification occurs, press S (S=Specify Additional Device).
4. When prompted, insert the diskette that was created from the SoftPaq file, and then press Enter.
5. Select "Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)" and press Enter.
NOTE: At this point, the following prompt MAY be displayed, depending on the version of your operating system CD. If the prompt is displayed, press Enter to use the default Windows driver and continue, if it is not displayed, continue with Step 6. The prompt reads as follows:
Windows already has a driver that you can use for
"Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)".
Unless the device manufacturer prefers that you use the driver on the floppy disk, you should use the driver in Windows.
S=use the driver on floppy ENTER=use the default Windows driver
6. Continue with the operating system installation, as prompted.
NOTE: If a problem is encountered when using the external USB floppy drive, refer to Microsoft Knowledge Base Article 916196: "A connected USB floppy disk drive does not work when you press F6 to install mass storage drivers during the Windows XP installation process."
Posted on Sep 09, 2008
I want to remove win7 from my compaq cq57 laptop (intel core) and replace it with xp pro
In your case try the RAM part 1st.
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode).
  • Uninstall last program(s) that was installed, again in safe mode.
  • Re-install Windows. Clean install works best.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 01, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Unistalling Microsoft VISTA HOME Edition
Are booting the laptop from the XP CD? If so it should just give you an option to delete partitions then format and install starts. If you try installing XP after Vista has loaded it wont let you as XP is older. Cheers from Scott
Mar 19, 2010 | Compaq Presario Notebook
Nvidia graphic driver problem
Sir,
This is the problem with XP. Your nvidia graphic drivers is not supported by XP. So go to manufacturer's website and download the appropriate driver for XP.
Thanks
Good Luck
Aug 17, 2009 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Unable to install windows XP on my Notebook
you can't install Windows Xp from witin Windows vista. (not backwards comparable).
restart the computer press F12 when the HP logo comes up. that will bring you into BIOS. select advace>>boot order.
select CD-ROM as first boot. HHD asn second.
exit the BIOS and restart the laptop with CD in the CD drive.
press enter when the system start to install from CD......
and follow the screen (must reformat the HHD).
Jan 27, 2009 | HP Pavilion DV5234US Notebook Laptop
How to disable sata in bios of compaq CQ40 laptops
have an compaq presario cq40-301tu laptop want to load xp already vista is loaded in that while installing xp i get an blue dump error & no setting in bios found to make sata compatible please give me the solution how i can install win xp2-
Nov 27, 2008 | Compaq Presario Notebook
Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
Drivers and installation
U COULD TRY REINSTALLING WINDOWS.AND SERVICE PACK
Sep 21, 2008 | Computers & Internet
How to install Widnows xp on HP Pavilion dv2000
Please help me, I bought a HP Pavillion dv2000 Laptop which came with a built-in Windows Vista. Thats cool, but the problem arises when I try to install windows XP. After inserting the Windows XP SP2 CD and after primary driver loading it is unable to detect my harddisk
May 07, 2008 | Computers & Internet
Computers & Internet Logo
868 people viewed this question
David Payne
David Payne
