Bought a noname mp3 player on ebay, had lots of trouble with it.Turns out to be LiSong branded. Wouldnt play wmas so I had to convert files to mp3, then had format problems. Hit delete all and now lost everything including set up. Disc provided wont load either. What now??
  • Doug Folber Sep 09, 2008
    Did what you suggested, then sync. my media player files into the mp3(took over 3hrs! ) and it WORKS!! Playing WMAs which it didnt before. Thanks so much!!!!
  • 6,487 Answers
Try to connect the player to your computer via USB cable and then hopefully it will be detected by the computer, If its detected double click Mycomputer icon and look for the MP3 player there, just right click on it then format so it will be clean...
Hope that helps.........
Posted on Sep 09, 2008
Some songs will not format to the player. how can i fix this problem
You'll need to convert the said incompatible formats to MP3 format. Its probably because its in WMA or AAC format which your player can't support. Use a free mp3 converter from www.download.com to convert the said files.
Try playing the files first on the PC, if it doesnt play, chances are there is protection embedded to the audio file and conversion wouldnt work either, have a cleaner version of the file.
Hope this helps, please rate if it does
levibit
Dec 18, 2010 | Audio Players & Recorders
No drivers to be found
search for drivers on mympxplayer.org. It's a website dedicated to mp3/mp4 players.
Sep 05, 2009 | Sony Audio Players & Recorders
My mp3 player wont play anything
You will need to make sure that your music files are either MP3s or WMAs. They cannot be AACs or MP4s.
Jul 16, 2009 | Finis Swi MP3 Player
I bought my daughter a sansa shake for christmas and it wont sync on any computer?
i wouldnt use sync feature for the shaker read the following:
check the file types from you music the shaker only plays MP3 and PCM WAV  file types. You may have WMA (if u used windows media player) which will not play on the shaker  (i had this same ploblem btw) you can easly find free music file converter software to change these files to mp3 or wav types (which i did), or you could rerip to songs from a cd and tell the windows media player to rip the files as mp3 types instead of the default wma format  from the windows media player widow :
tools >> options >> Rip Music >> under format select mp3 (theres a wav option but i used the mp3 option to be safe)
do not use the sync feature it will automatically convert your files to to wma (why? i dont know) instead copy the files directly from the folder that contains them :
right click the file you need to put on the player select open file location drag and drop to the player (or copy/paste if you want).
hope this helped =P
Dec 31, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
HELP PLEASE
Check the files that say "non-supported format" by right-clicking one and going to "properties". Click the "license," "digital rights mgmt," or "media usage rights" tab (wording varies by configuration). See if the license is expired or says, does not support transfer to device. Make sure your music svc sub is up-to-date.
If so, convert them all to mp3 format - problem solved.
-Tha Mp3 Doctor.
May 09, 2008 | Samsung YP-T10 Digital Media Player
Hello!!
you likely have a music file other than an mp3 on there ( possibly wma or m4a file) i had a bunch of wmas on mine and wouldnt play, deleted them and added mp3 files and mine worked fine.
Apr 17, 2008 | BenQ Joybee 130 MP3 Player
Mp3 format??? HELP, PLEASE!
I don't know about converting the MP3s to WMAs, but I had the same problem with "corrupt files."
What fixed that for me was instead of dragging and dropping files onto the Sansa, I synchronized them using Windows Media player, but only do 10-20 songs at a time, because if you try to do too many, they probably won't show up. I know it's tedious and annoying, but that's what did it for mine :) I hope this helps.
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
Coby mp3 player problem
Write the songs to a CD (or a CDRW) first, then re-rip them to Windows Media Player/iTunes/whatever as mp3s, or unprotected WMAs.
Honestly it's easier to burn and re-rip than remove the copy protection. When you burn it to a CD, the DRM goes away, and you'll have a new file that actually plays on your player.
Dec 23, 2007 | Coby MP-C883 MP3 Player
66 people viewed this question
 Grubhead
Grubhead
