Question about Microsoft LifeCam VX-3000 Web Camera
Webcam installation After installing the software and attaching the webcam to the usb port it will not turn on. The help says it must be focused but there is nothing that comes up to help with that. One message was that there were no drivers.
  • oldurgan Sep 15, 2008
    My Web Cam was working it look same its brand is different(quake.)
    I found driver from the internet. But it does not work.
    it says no hardware found. Web cam says there is no driver found.
    it seems driver and hardware does not see each other.
    I can not solve the problem.
I have a problem my webcam
Posted on Oct 02, 2008
How do i get my logic3 webcam to work
Most modern operating systems come with plug-and-play for devices such as webcams, so simply plugging the webcam into the USB port will most likely trigger Windows to install the necessary driver software.
From there, start whatever software you're using the webcam with (e.g. Skype, AIM) and check that it recognises the new camera. The settings menu will have an option to select the webcam, and will probably show a test image from the camera.
Focus it using the manual focus and you're good to go.
May 15, 2012 | Computers & Internet
Web comera is not display
The very first step is of course to check your webcam connection. Most webcams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in webcams this steps does of course not apply. Many new laptops have a build-in webcam. Also try connecting your webcam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem
jackpot00_6.jpg If the device is not recognized in Windows XP, it will be listed under Other Devices.jackpot00_7.jpg In either case you can try to update the drivers. Right-click the device, and in the popup menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
After uninstalling the software, restart your PC and then reinstall the webcam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your webcam during the software installation.
If the drivers and webcam software are correctly installed, and you still cannot see any video, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the webcam feature. If you have multiple devices that qualify for video, you might need to select your webcam device as the source for the webcam feature in that program.
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
Lastly, if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
Dec 03, 2010 | Computers & Internet
My picture is very fuzzy and out of focus
Some webcams have a focus ring around the lens that rotates to sharpen the image
Others rely on software in the webcam dashboard that zooms in or out to achieve the best focus
Using a webcam designed for a 2.0 USB connection in a 1.1 USB port will affect the quality
Make sure you have the support software loaded on your computer
Visit the Microsoft hardware support page
http://www.microsoft.com/hardware/download/download.aspx?category=ICE&type=LifeCam&sku=68A-00001
Fill in the details and click 'GO'
Click on the link:-
"Microsoft LifeCam Readme and Troubleshooting Information"
All the information you require should be found here, Including the latest software to download and Customer Support
Check out any additional software you have to download as well as the Lifecam software.
Procedure
Close all programs while uninstalling - downloading and uploading software
Disconnect your webcam
Uninstall the current webcam software on your computer
Restart computer
Download the Installation package from Microsoft
Run the installer and choose your options when prompted
Connect your webcam when prompted.
Sep 02, 2010 | Microsoft LifeCam VX-1000 Webcam
My webcam is not working.i can't buy other webcam because my webcam is attached to my laptop on upper portion of the monitor.pls help me to recover my webcam.my teacher said its because of the virus coz my...
Dont worry just follow the easy steps
Steps to solve the webcam problems The very first step is of course to check your webcam connection. Most webcams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in webcams this steps does of course not apply. Many new laptops have a build-in webcam. Also try connecting your webcam directly to your PC instead of through a USB hub (if you are using one).
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
windows-xp-other-device.jpg If the device is not recognized in Windows XP, it will be listed under Other Devices.
windows-vista-device-error.jpg In either case you can try to update the drivers. Right-click the device, and in the popup menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the webcam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to uninstall the software that came with your webcam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party uninstaller.
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Lastly, if your webcam’s image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
video-capture-properties.jpg Do keep in mind that not all settings will be enabled depending on the webcam and the webcam driver installed on your computer. In the example you can see that some settings are disabled. The example shows the video capture properties for an Acer Crystal Eye webcam.
Jul 02, 2010 | Computers & Internet
The picture in my logitech webcam is not clean but cloudy
Launch the logitech toolbar from your desktop or 'All Programs'
Start your webcam from the 'Quick Capture' menu and then move to the 'Settings' menu - try and trim the image from here.
1) Try rotating the focus ring around the lens to achieve the optimum clarity
2) Make sure you have DirectX installed
3) Check your USB ports are 2.0 ('enhanced' - on the USB info in Device Manager) My laptop has 4 USB ports
2 are 1.1 and 2 are 2.0. The difference it makes to my logitech is amazing
4) If all else fails - re-install your software
Jun 11, 2010 | Logitech Webcam
I can not insttal my webcam how i do it? my webcam viewsonic 'vx2255wm
Here's the Webcam Installation (taken from user Guide)
  1. Insert the Webcam Wizard CD into your CD-ROM drive, and follow the screen instructions to install the program.
  2. Connect the monitor to one of the computer's USB 2.0 ports, using the USB 2.0 cable that is included with the monitor.
  3. The computer will detect the camera automatically and the webcam icon will appear in the My Computer window.
  4. Please refer to the Webcam User Guide on the Webcam Wizard CD for detailed instructions on using the webcam.
here i include the Webcam Driver:
http://www.viewsonic.com/support/downloads/drivers/_download/VX2255wmb_WebCam_Utils.zip
(simply click on the link to download the webcam driver)
hope it help
regards
Apr 17, 2010 | Computers & Internet
Gigaware webcam installation not working
Remove the CD, then go to the program files folder and remove the folder that applies to this device. Remove the device from the USB port.
Reboot the PC.
Reinstall the software before you attach the webcam to your PC. Only attach the device when directed by the installation program, or after you have fully installed the software.
It's a pain in the ****, but reboot after you finish installing the software and then attach the device. This will allow the device manager utility to fully recognize the device and apply the appropriate drive files.
Rich
Dec 15, 2009 | Radio Shack VGA PC Camera Webcam
I have installed the program erased it and installed it again plus i have focus it several times and it is still blurry
Normal 0 Try disconnecting the camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work. Hope this helps. Bud
Jan 21, 2009 | Micro Innovations IC50C Basic Webcam
Webcam isn't detected
reconnect webcam usb port, then restart your PC. then, attact usb port again, try to attach first at front usb port of your CPU, if stil doesnt work, attach your webcam at the back usb port of your CPU.
Hope it will work.
Thank you.
Jul 30, 2008 | Microsoft LifeCam VX-1000 Webcam
Help me
1:)Do you have installed driver?
2)The green light on webcam working???
Nov 01, 2007 | Radio Shack VGA PC Camera Webcam
Microsoft LifeCam VX-3000 Web Camera Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
