My screen on my NEW gateway laptop has cracked and spidered down the ENTIRE screen so I can no long use it..I have only had this laptop for A MONTH AND A HALF! No one at gateway will help with this problem..What is the deal???
    Problem Solver:
  • 10 Answers
You or someone who has had the laptop has obviously dropped the laptop or sat something heavy on top of the laptop there is no way the would randomly happen.
Posted on Sep 09, 2008
Cracked LED screen repair
Ignore it.
Take it to an Apple dealer to get it replaced.
Nov 02, 2013 | Apple MacBook Pro Laptop Computer with...
Can laptop screen spider crack without being dropped?
One of a few things may have happened. When the laptop was closed last, there may have been something on the keyboard (pen, toothpick etc) that could have caused the crack - The laptop may have received an impact that she was not aware of - the crack may have been pre-existing (cracked slightly a while ago) and finally gave way. Here's something else I have encountered......When she opens and closes the laptop, does she usually lift the lcd from one corner only, both corners at the same time, or from the centre? If you open a laptop by one corner of the lcd only, you are flexing the lcd every time, and this can weaken it and eventually cause a crack. Also, if you try to open the laptop from one corner, and the lid is still latched, this flexes the lcd as well. Anyhow, Unless your warranty will cover it, go to www.laptopscreens.com
and order a new lcd panel. I have ordered from this site a few times now, and their prices are by far the best I have ever seen ($80 average). Order the screen, and if you're not comfortable installing it yourself, take it to a good service shop and have it done.
Hope this helps!
Joe
Mar 22, 2012 | HP Computers & Internet
I dropped my dell notebook on the floor. The screen is 80% frozen however when I turn it off and reboot I can tell from the little corner I can see that the computer function but the screen stays stuck....
Try connecting an external monitor to your laptop via the 15 pin VGA connector located on the left side of the laptop.If the laptop display is normal on the external monitor then most likely your LCD (liquid crystal display) panel is damaged and needs to be replaced. The spider web effect is due to cracked display panel.
Sep 12, 2011 | Dell Inspiron 1525 Notebook
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
I have a cracked/spidered screen going on. How did it happen & can it be fixed?
> how did it happen?
Physical force sufficient to "crack" the glass.
> can it be fixed?
Yes, by taking the computer to a qualified technician, for removal of the broken screen, ordering of a new screen, and installation of the new screen.
Sep 13, 2010 | ASUS Eee PC 900 Notebook
Screen has spider web crack on left end.
The only fix is to replace the screen, but with very few exceptions it's always cheaper to replace the entire tv.
Sep 08, 2010 | Televison & Video
Spiderweb effect on lcd screen
only solution is replacing entire screens. very expensive, try finding manufacturer on internet.
Dec 02, 2009 | Televison & Video
I have a 6 month old Ricoh R8 camera cracked screen
I would send camera away to be fixed since its only new let the profesionals replace it. tell them when you got it the screen was cracked . Up there for thinking, down there for dancing as they say
Nov 30, 2009 | Ricoh R8 Digital Camera
Hello. I am on a laptop right now, but my gateway desktop is acting weird. I was playing Rome Total War, when my screen started having strange colors and the computer shut down. Everytime I boot the...
you may got infected...first run scan on the system and then reboot and see if you normally use it then try going to play again if that happen again then you need to get new video card
Nov 07, 2009 | Office Equipment & Supplies
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
Open Questions:
The Best Unlimited Cloud Data Backup and Cloud Storage Services You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Cloud Backup For Small Business services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Server Cloud Backup Solution Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Backup Pricing Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jun 25, 2018 | Best Computers & Internet
Computers & Internet Logo
David Payne
David Payne
