Question about Olympus Camedia C-730 Digital Camera
Setting dates to pictures
How can i set the name of the picture to be the date in which picture was taken?
    Scholar:
  • 124 Answers
Choose MENU and TAB SETUP, you can choose the pattern of the file name. for example - "my picture XX" when XX represents a serial number. im not sure if auto date insert is possible, but check menual carefully, it may surprise us both.
Posted on Feb 22, 2006
Delete date from photo
That is correct. The date setup only affects pictures when they are taken; it will not alter pictures that have already been taken.
If you want to remove the date from a picture that already has it, you have to remove it the same way you would remove any other unwanted object from the picture.
Feb 21, 2013 | Vivitar Vivicam T027 Digital Camera
I have a Lumix DMC Z57 and would like to set it so when I take a picture the date the date will appear on the picture. Is this possible?
HMMM, I know the date is recorded on the digital file when it was taken and what the camera settings were. I know when I transfer mine to the hard drive i organise bu the date taken. so this info is there in the meta data recorded with each exposure. It sounds like you want it displayed on the pictures Too?
In Picasa( the free google software) File info is displayed at the bottom of each phota and a right click on the image and selecting properties reveals the meta data Camera date, date digitised, modified ect.
Feb 20, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
I want to switch off the date stamp in my pictures taken with A480, please.
Press Menu, scroll down to "Date stamp" and across to select off, date or date and time, then press menu again. The date stamp only works in Postcard mode, so if you set a different picture resolution, that will also stop the pictures being date stamped.
Dec 19, 2010 | Canon PowerShot A480 Digital Camera
How do i get the date to print on my pictures. also the descreption of each setting of the dial on top
Some cameras let to print the date to pictures and some others not. You should say the brand and model name first.
Generally you should enter to settings and turn the position of this feature to on. Then you may control it with the below explanations.
1. Turn on the camera.
2. Enter to settings.
3. Find this feature to turn it to on position.
4. Be sure that you save this setting.
5. Take a picture.
6. Turn the mode dial button to view mode.
7. Look at the latest picture that you have taken.
8. Zoom out the picture and look at the right bottom of the picture.
That is all.
I hope it will help.
Jun 15, 2010 | Cameras
I accidentally set the date imprint on my camera. I'm wondering if there is a way to get the date taken off of the front of the pictures I have already taken.
From the manual, "Imprinted dates form a permanent part of image data and cannot be deleted."
The best you can do it to make sure that Date Imprint is turned off for future pictures. The camera still records date/time info into each picture file, and many printing programs can imprint that onto the picture at printing time. The good ones print it on the back, so as not to interfere with the image. Either way, you can always add the date to the picture, but you can't remove it once it's there.
May 14, 2010 | Nikon COOLPIX S51 Digital Camera
Can i take the date imprint off a picture after it has been taken
no you cannot edit the date imprint within the camera once its been clicked. you can just turn that setting off so that the date dosnt show up on the picture or change the date in your camera & click pictures again to your desired date
Apr 21, 2010 | Pentax Optio W80 Digital Camera
Hello I need help, How would I know the pictures
First of all, your camera would have to have the correct date and time set on it before the picture was taken. Then, when the pic is downloaded to your computer, you can place the cursor over the picture file and the date and other info will pop up.
Dec 17, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
DATE ON PICTURES
In the Camera Settings there is an option to Enable/Disable the date stamp. Look for that option and enable it to get the date on your clicked pics. In the settings only you will find the clock settting / date/time settings to adjust the date and time. Refer your manual.
Jul 22, 2009 | Cameras
Need to change the date of previous taken pictures
load the pictures to an computer and click on characteristic trait
and rename the date
Apr 03, 2009 | Fuji FinePix A340 Digital Camera
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
huetrichard@gmail.com
Feb 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Olympus Camedia C-730 Digital Camera Logo
54 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
