Cars & Trucks Logo
Posted on Aug 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My feul pump is wired incorrectly I need a dugram to wire my fuel pump correctly on a 1995 Dodge Dakota V6 3.9. The fuel pump is brand new. the Computer works. all the relays works. We ran a wire direcly from the fuel pump to the relay bock and the fuel pump runs but wont cut off and the fuel pump wont run without running this wire directly to the relay box. Whats the problem?
Anonymous
Level 2:
Guru:
  • Expert 302 Answers
  • Posted on Aug 26, 2011
Anonymous
Expert
Level 2:
Guru:
Answers
302
Questions
Helped
86801
Points
653
Here is a diagram from Chilton's manual.
1995 dodge dakota, fuel pump not working after it warms up, checked relay, god what else could it be?
Could be your pump going out. Only way to be sure is check if power is available at the fuel tank connector when the pump isn't working. If a voltmeter or test light still shows power on the fuel pump wire, then you probably need a new pump.
1995 slt dodge dakota 3.9L one cylinder not firing
how many miles, several causes, fouled spark plug, damaged spark plug wire, bad fuel injector, i would check plug and wire first
5helpful
2answers
1995 dakota fuel pump relay. If the relay is bad,
If fuel pump relay is bad yes it will still get spark.
Sonds like you do have a fuel pump, or fuel pump relay problem, most likely the pump.
2helpful
Is there access to the feul pump thru the back seat of a 2001 dodge dakota quad cab?
no access to tank, you must remove the fuel tank to replace the fuel pump. Just did my Dakota, was a real pain
3helpful
Where is the feul fifter for 1995 dodge dakata?
the 4 cylinder 2.5L fuel filter located under the bed of the vehicle along the left side frame rail. the V6 and V8 fuel fuel filter located in the fuel pump module,on the top of the fuel tank.
Feul pump dodge 2001
In the fuel tank. If you're wondering if it works or not, you should be able to hear it cut in for about 2 seconds when you first turn the key on.
1helpful
2answers
Changed Fuel Pump and now gauge does not work
you have messed up and not hooked the wires up for the gauge you have them reversed positive to negitive and vise versa common mistake for someone who does not do it for a living.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
